Alaska Series Motor Bracket
kennharriet
City/Region: Grangeville
State or Province: ID
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Sun Mar 21, 2021 6:03 pm    Post subject: Alaska Series Motor Bracket Reply with quote
http://www.c-brats.com/modules.php?set_albumName=Lochsa&id=F24733CB_9F68_446D_98B1_C0E409D59FD6_001&op=modload&name=gallery&file=index&include=view_photo.php[/img]
CC Rider
City/Region: Tsawwassen
Vessel Name: CC Rider
Photos: CC Rider
PostPosted: Sun Mar 21, 2021 6:09 pm    Post subject: Reply with quote
Here's the pic....
MMSI#: 316033635
kennharriet
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Sun Mar 21, 2021 6:21 pm    Post subject: Reply with quote
Thank you CC for adding my photo. Just wanted to share that I had an aluminum motor brackett fabricated by a local welder to replace the stock bracket. The stock bracket had rusted and rust stained the gelcoat on the cabin top. It ran about $200 but is stronger, rustproof and about the same weight. Duplicates may be a bit cheaper as he now has a pattern. If anyone is interested send me a pm. Ken
Catch 22
City/Region: Lynnwood
Vessel Name: Catch 22
Photos: Catch 22
PostPosted: Sun Mar 21, 2021 11:28 pm    Post subject: Reply with quote
Which model raft? Do you know if they are all the same?
Kevin Richards - Catch 22
kennharriet
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Mon Mar 22, 2021 10:19 am    Post subject: Reply with quote
We have the TDS 220. I could not tell from their website if the tenders had a common tube diameter. Your cheapest option might be to take your steel bracket to a local welder. I considered stainless but cost and weight won out. The aluminum is much easier to take on and off, mostly because it is not corroded. Good luck. Ken
Catch 22
Photos: Catch 22
PostPosted: Wed Mar 24, 2021 3:53 pm    Post subject: Reply with quote
I have decided to build my own as well. I should have the new boat in a week or so and be able to model the bracket after the supplied one. I will make it out of aluminum as well.
Page generation time: 0.0271s (PHP: 61% - SQL: 39%) - SQL queries: 20 - GZIP disabled - Debug on
