iPad brackets and forum searches
tparrent
City/Region: Apex
C-Dory Year: 2017
Vessel Name: Tomfoolery
Photos: tparrent (TBD)
PostPosted: Sat Nov 28, 2020 4:10 pm    Post subject: iPad brackets and forum searches Reply with quote
Any suggestions on installing an iPad bracket? Brand, location, etc.
Any suggestions? Is that a serious question? Very Happy I know this has likely been covered many, many times but I am struggling with the C Brat forum search.
How can I search for specific phrases? Most searches I try result in either nothing or a dozen posts that don't actually cover the topic I'm looking for.
Teach a man to search and he won't annoy you with obvious questions Wink
PostPosted: Sat Nov 28, 2020 4:20 pm    Post subject: Reply with quote
RAM Mounts. You can get a base that attaches to your dash, and then pick out attachments for your size iPad.
RobMcClain
City/Region: Summerlin, NV
State or Province: NV
Vessel Name: Freedom
Photos: Freedom
PostPosted: Sat Nov 28, 2020 4:56 pm    Post subject: Reply with quote
I second the suggestion of using a RAM mount. I use one to hold my iPad Air and it has never popped loose. It has a solid suction cup base that really holds, even in some pretty uncomfortable conditions. Plus, I like that I can vary the screen display from horizontal to vertical, and vary the screen angle from nearly straight to leaning fairly far back - if that description makes any sense...
Rob
PostPosted: Sat Nov 28, 2020 7:03 pm    Post subject: Reply with quote
While you are at it, install a couple of 12V USB 2.4 amp outlets, we have one by the cig lighter and one on the forward shelf by navigator's seat. That will keep the I pad charged up.
NORO LIM
City/Region: Olympia
Photos: NORO LIM
PostPosted: Sat Nov 28, 2020 7:33 pm    Post subject: Re: iPad brackets and forum searches Reply with quote
tparrent wrote:
. . .I know this has likely been covered many, many times but I am struggling with the C Brat forum search.
I assume you have tried the on-site Google Custom Search feature in the box at the upper left of the page? Except for some ads that will appear at the top of your search results, that box will confine your search to the C-Brats site. You can refine your searches there by using standard Boolean search operators, like quotes around exact phrases. See: https://library.alliant.edu/screens/boolean.pdf
Personally, I have always preferred the Google Advance Search: https://www.google.com/advanced_search
You can really customize a search as well as limit it to a specific domain like the C-Brats. Just fill in the blanks. It works very well.
There are things no search system is going to overcome. There will always be the maddening high jacking of threads, misuse of terminology, repetitive posts, duplicate threads and assorted other characteristics of a happy band of disorganized amateurs talking about their favorite subject. In the end, a lot of time just plowing around more or less randomly will go a long way toward helping you know what to search for and how to find it. Anyway, annoying questions are just another of the many joys of this place.
Bill, Formerly on NORO LIM
2001 CD 16, 2001-2006
2006 CC 23, 2006-2014
Peter & Judy
City/Region: Olds
State or Province: AB
Vessel Name: Mistaya
Photos: Mistaya
PostPosted: Sat Nov 28, 2020 9:14 pm    Post subject: Reply with quote
I use a Ram mount with a suction cup, holds rock solid, but I do have a safety cord on the mount.
Peter & Judy Haase
Buffalo Horn Ranch
HMCB Mistaya
PostPosted: Sat Nov 28, 2020 11:50 pm    Post subject: Reply with quote
Bill, I loved your response. I have never used anything but the C-BRAT search. I learned that you have to use the "and" in all caps to do more than one word but often that works with 3 or 4 words. And Yes, there is always other stuff to sort through, but it is always fun Laughing
Thanks for all your comments here, Much appreciated.
PostPosted: Sun Nov 29, 2020 10:16 am    Post subject: Reply with quote
Here is our iPad mounted on a RAM mount on the underside of the electronics shelf. There is a power cord that goes down to a USB power adapter in the 12 volt socket. This was how we navigated the Great Loop over eight months in 2017. We only used the antique Raymarine C-80 as a depth sounder and odometer since we did not have any cartography for it.
Hunkydory
State or Province: WY
Vessel Name: Hunkydory
PostPosted: Sun Nov 29, 2020 12:02 pm    Post subject: Reply with quote
We have been using the IPad increasingly more each year for navigation & planning since 2011. Originally it was mounted like in this photo using a Ram mount.
Later, I lowered the IPad slightly by switching to a magnetic mount directly off the dash for better vision & used the Ram mount to hold the IPhone in a higher position with neither interfering with forward vision.
In 2011, we purchased the Navionics app on the ipad for 50 some dollars. Garmin stopped updating it & added a yearly subscription that cost 50+$ & I held out using the old downloaded maps on the app for several years, but with continual glitched on the old app, finally did the yearly subscription route, when it was lowered to about $25 per year & could be used on 3 devices. I’m extremely pleased with how it works & think the price now reasonable for my use on different IPads & the IPhone. In fact it has become my main navigation plotter & I presently use the older Garmin charts more for back up & different screen size views & to run the auto pilot. I plan to continue using the Navionics app until Garmin either discontinues the deal or makes the price not worth its advantages.
PostPosted: Sun Nov 29, 2020 5:13 pm    Post subject: Reply with quote
Jay,, great reminder. It appears as if the US and Canada is currently $22 and US only (lakes and ocean) is $15, it may be a limited offer until Dec 30??.
I still have my old charts, preserved so far--but at that price, I'll subscribe again!
I also have been using Aqua Map because it has Active Captain overlaid. At this point it seems to have been mostly the older Active Captain--but since Garmin bought Active Captain, there have been far fewer new update. Aqua map is changing its plan because of some "conflict" with Apple. It will be available for free, but you have to download the new software. I don't know if it will still have active Captain.
Gene Morris
City/Region: Eureka CA
Vessel Name: Reef Madness
Photos: Reefmadness
PostPosted: Sun Nov 29, 2020 8:45 pm    Post subject: Reply with quote
All of my mounts are RAM The co-pilot has her IPAD 12.9 mounted at her side with a RAM X mount and a 3 inch extension, Very easy to put the IPAD into and very secure. I also added a 12 volt outlet next to it.
I use her charts on Navionics more than I use the Garmin MFD at the helm.
tight lines
Page generation time: 0.0398s (PHP: 65% - SQL: 35%) - SQL queries: 28 - GZIP disabled - Debug on
