Fixing the gas tank problem
clayhubler
City/Region: La Center
Vessel Name: Hammerhead
Photos: Merlin and Hammerhead
PostPosted: Mon Nov 09, 2020 2:20 am    Post subject: Fixing the gas tank problem Reply with quote
Finally getting time to work on the gas tank problem that is common in these boats. What a joke it is that they came from the factory like this. Hoping the picture posts, first time trying to get that figured out.
Transom has some rot also.
Hoping to have this baby back together before christmas.
Oh, yeah, the area I circled appears to be a patch of some kind. What do you think?
Clay
Hammerhead
2003 22’ Cruiser
Merlin
1986 26’ Cruiser
clayhubler
PostPosted: Mon Nov 09, 2020 2:22 am    Post subject: Reply with quote
Well, I guess I'm posting micro sized photos...
Its bigger in the album.
Okay, that only took two hours. Took less time to pull the motors and tanks...
PostPosted: Mon Nov 09, 2020 2:35 am    Post subject: Reply with quote
You can click on the image in your album to make it larger for viewing, right?
If you want the photo in the thread to be larger, click on it in your album, it will enlarge there, then click on it to get the image address to copy into the thread.
PostPosted: Mon Nov 09, 2020 11:58 am    Post subject: Reply with quote
There you go. I got the photo to grow.
You had the right idea for embedding the image but the link you used between the image tags was not the right one. If you click on the pic in your album, then right click on the enlarged image you should find an option to copy the image address or URL. That is what needs to go between the tags.
If you want, I can delete the messages talking about the micro sized photos so your thread can get back to the business at hand.
Best of luck with your fix and I hope you get it done well before Christmas.
clayhubler
PostPosted: Mon Nov 09, 2020 12:51 pm    Post subject: Reply with quote
Okay, I think I got it now. Click on the image first so it is enlarged, then copy the address.
Thanks for the help on that. Is there a way to post a picture from a file on the computer or does it have to go into the album (or at least on the web) first?
I'll try to post a few more pics now
WeekiTiki
City/Region: Weeki Wachee
Vessel Name: Just Cruisin'
Photos: WeekiTiki
PostPosted: Mon Nov 09, 2020 1:06 pm    Post subject: Reply with quote
Sucks that they screw into the floor to keep tanks in place
I've got to repair mine too one of these days
Right now they're just sealed with bolts held in place with marine caulk
have to make sure you get all that wet wood out
Weeki Wachee
clayhubler
PostPosted: Mon Nov 09, 2020 1:53 pm    Post subject: Reply with quote
Here is another picture of the patch in the corner
PostPosted: Mon Nov 09, 2020 2:44 pm    Post subject: Reply with quote
That corner "patch" is unusual. It looked as if someone put a pice mat with resin in the corner after the boat was laminated in the mold. Does not look like a "patch, but you never know.
Good on routing out and filling the holes. What did you use as filler with the epoxy?
I would glue strips of compost (Like PVC lumber) onto the floor and put the screws into that. That is what the more recent boats have done...about 2006-7 era in the 22's
clayhubler
PostPosted: Mon Nov 09, 2020 3:02 pm    Post subject: Reply with quote
Yes, I was wondering if it was a shim for fuel tank or something, but it goes up the side a ways. I don't know what it is. I don't know if the boat was in some kind of accident and sustained damage there from a hit. I don't see any evidence of that on the outer hull.
I haven't filled the holes yet. I'm trying to get them dry still. I may have to cut the skin off in a few areas and get some balsa. I have west system resin with cabosil thickener, but some of the holes are pretty large. Its cold here, but I don't want the plugs to build up too much heat.
I think I'm going to have to cut a small piece of the lower transom out also...
clayhubler
PostPosted: Mon Nov 09, 2020 3:06 pm    Post subject: Reply with quote
Wiki Tiki
It may not be as bad as you think. I was expecting to cut out the entire cockpit floor but the water didn't migrate too far from the holes because it is end grain balsa.
Its hard to get it to dry though when it 35 degrees outside
PostPosted: Mon Nov 09, 2020 3:16 pm    Post subject: Reply with quote
Basically you want to remove wet core. Undercut the fiberglass so the plug is secure and acts as a binder between he cockpit floor and outer hull skin.
I like to use a bit of medium density filler along with the cabosil. Seems to make the epoxy plugs less brittle and easier to put a screw in if you wish to do that.
I don't think this is a "repair from outside"--inner aspect.
If possible try and work in temperatures of at least 55*
What is the issue with the transom? Wet, delaminated by tapping? Drilled holes or over drilled and found wet material?
Good going!
clayhubler
PostPosted: Mon Nov 09, 2020 3:39 pm    Post subject: Reply with quote
Yes, I drilled out the holes where the engines were mounted and one of the lower holes is wet and rotten. Only one at least. I will drill a few more exploratory holes when I get time.
Kind of hard to see, but the material is wet and very soft. All the other holes were dry and solid. This hole is the port engine, lower right mounting bolt.
PostPosted: Mon Nov 09, 2020 3:58 pm    Post subject: Reply with quote
Good idea to cut back and fill on all of the holes. This gives a "doughnut" to compress against when the bolts are rightened. Most likely the damage is localized.
The rigger should put a metal plate inside the transom between both sets of bolt holes to spread the load out. Virtually no one puts the epoxy or solid material as should be done.
clayhubler
PostPosted: Mon Nov 09, 2020 4:32 pm    Post subject: Reply with quote
I was considering putting a piece of 1/4 thick by 4 inch aluminum flatbar as a backer for that very reason.
Here are some more pics. The plastic cap on the transom is coming loose in one spot, and I worry about water intrusion there also:
I also removed the plug and was blown away because the wood around the hole was never even sealed with epoxy. It was wet but not rotten at least. Unbelievable to me:
I put the trex on there when I got the new fishfinder. Will the trex work or should I tear it off and buy some starboard. I actually am going to have to buy some starboard anyway.
PostPosted: Mon Nov 09, 2020 5:27 pm    Post subject: Reply with quote
... I would glue strips of compost (Like PVC lumber) onto the floor and put the screws into that. That is what the more recent boats have done...about 2006-7 era in the 22's
IME, the PVC lumber you get at places like Home Depot is ok when you use it as lumber (say siding a house). It's not that good at holding screws with a tension load on them, it's too soft.
Something like Starboard or maybe Trex decking material might be better.
Page generation time: 0.055s (PHP: 56% - SQL: 44%) - SQL queries: 32 - GZIP disabled - Debug on
