Condensation
C-Belle
City/Region: Victoria
C-Dory Model: 29 Venture
Vessel Name: C-Belle
Photos: C-Belle
PostPosted: Mon Nov 02, 2020 6:46 pm    Post subject: Condensation Reply with quote
This is the time of year where C-Belle starts to get condensation along the deckhead where the interior lights and speakers are mounted. I took the starboard deckhead off and sprayed the fiberglass with a clear rubber spray to create a barrier. It's been a week now and that side has stayed dry so will do the same to the port side next. An easy fix to stop the dripping.
Rolly
PostPosted: Mon Nov 02, 2020 7:38 pm    Post subject: Reply with quote
What spray are you using?
PostPosted: Mon Nov 02, 2020 10:48 pm    Post subject: Reply with quote
For those who don't understand the terminology the "deckhead" is the ceiling or underside of the deck.
How did you take the "Deckhead" off? I am also interested in what spray you used?
When we have had condensation it has been mostly in the forward cabin when we were sleeping --and also in the rest of the boat, including cabin wall sides, windows etc.
bobjarrard
City/Region: Boulder City
State or Province: NV
PostPosted: Tue Nov 03, 2020 12:35 am    Post subject: condensation stopper Reply with quote
Mascoat but there are others also. There is a thread or two here on the site. Marinauts used this material for a bit. They are nice folks but this is a large application material but they have sold smaller quantiles. It can be brushed or rolled but a strong airless is best. Two to three coats is likely optimal and some folks have added a latex overcoat to make it easier to clean but that cuts down on the soundproofing qualities. In my mind, much better than glued on foam, liners, or the like. Also, real vents and dry heat, fans, and did I mention ventilation? On my last boat I used a box fan over the forward hatch (110V) with a small thermostatically controlled heater from Walmart (also 110V), and the the boat cover well off the deck (I have been called something like the word "deckhead" but I forgave that person. Bob Jarrard
https://www.mascoat.com/marine-coatings-applications.html
PostPosted: Tue Nov 03, 2020 4:49 am    Post subject: Reply with quote
C-Belle is a 29 Venture, not like most of our boats. Here is a pix from the C-Belle album:
"Port deckhead photo"
Might be an indication of what happens when there is a liner involved.
C-Belle
Photos: C-Belle
PostPosted: Tue Nov 03, 2020 1:06 pm    Post subject: The spray I used was called Flex Seal Reply with quote
https://www.canadiantire.ca/en/pdp/flex-seal-liquid-rubber-sealant-coating-clear-14-oz-0670885p.html
I wasn't using it to stop leaks but to create a coating over the fiberglass. I also have two Stor-Dry fans.
One can gave me three + good coats for that area. I'm gonna do the Port side and take photos next time.
Page generation time: 0.0268s (PHP: 67% - SQL: 33%) - SQL queries: 19 - GZIP disabled - Debug on
