Tomcat 255 In Water Bridge Clearance
flboy77
City/Region: Sarasota
PostPosted: Thu Oct 29, 2020 11:54 am    Post subject: Tomcat 255 In Water Bridge Clearance Reply with quote
Hello All
Does anyone happen to know the bridge clearance of the Tomcat 255 in water? Trying to see how easily it will fit under the bridge coming out of our canal
Thanks in advance
Robert H. Wilkinson
City/Region: Port Ryerse
State or Province: ON
Vessel Name: Romakeme IV
Photos: Romakeme IV
PostPosted: Thu Oct 29, 2020 7:04 pm    Post subject: Reply with quote
If no reply you could send a pm to gulfcoast john or thataway. One of them can probably give you the air draft of the Tomcat.
Regards,
Rob
gulfcoast john
City/Region: PENSACOLA
C-Dory Year: 2010
Vessel Name: Cat O' Mine
Photos: CAT O' MINE
PostPosted: Thu Oct 29, 2020 8:08 pm    Post subject: Reply with quote
Rob,
I PM'ed Tim that we got Cat O' Mine under 8 feet bridge clearance to do the Lachine Canal through Montreal by removing the HDX24 radar dome while leaving up a radar platform a bit above the Coleman 13.5 BTU Coleman rooftop air conditioner we had at the time. Boat is in the shop so I can't do exact measurements, but I think with 13.5 rooftop AC he'll be an inch or inch and a half under 8 feet bridge clearance even with a radar platform just above the AC.
If not, Tim could add 900 lbs of gas, plug the aft cockpit scuppers and add 400 lbs of water to each sponson while disabling the bilge pump floats, and three 300 lb 'good ol' boys' with strong wrists and their 150 lbs of beer and a Sarasota astronomical low tide and squeeze under.
Since I can't measure, if other TC255 owners have a more precise reassurance, sing out! I'm depending on memory, and it's not what it used to be.
What was the subject again?
Cheers!
John and Eileen Highsmith
2010 Tom Cat 255, Cat O' Mine
Yamaha F150, LXF150
gulfcoast john
C-Dory Year: 2010
Photos: CAT O' MINE
PostPosted: Thu Oct 29, 2020 8:09 pm    Post subject: Reply with quote
duplicate, or maybe not...I don't remember.
PostPosted: Thu Oct 29, 2020 8:42 pm    Post subject: Reply with quote
Well, Journey On isn't a Tomcat, but the cabin is similar to a Tomcal, and the freeboard doesn't seem much different.
So we got Journey On under a 8' 6" bridge in the delta, near Sacramento. Left the radar on the high arch, lowered the antenna. Just to see if I could and it saved 5 miles of travel.
Robert H. Wilkinson
Photos: Romakeme IV
PostPosted: Thu Oct 29, 2020 10:51 pm    Post subject: Reply with quote
Thanks John - your memory hasn't forgot how to instill humor in a post! Laughing
You forgot one option though. He could ride the trough of a wave in like this - https://theskipper.ie/30-mtr-98-4-ft-wave-recorded-off-irelands-west-coast-this-morning/?fbclid=IwAR2w4PVITBwUXO4t64qf6RDp1z1jr2KtGFLvkG7l4UNy8ZnlSdlMerADkZI
If the trough wasn't deep enough the wave would at least take the bridge out - so ether way - problem solved!
Page generation time: 0.031s (PHP: 61% - SQL: 39%) - SQL queries: 23 - GZIP disabled - Debug on
