New Trailer I think need some adjustments
ssilver
City/Region: Albany NY
State or Province: NY
Vessel Name: Pearly Shell
Photos: Pearly Shell
PostPosted: Fri Oct 16, 2020 1:14 am    Post subject: New Trailer I think need some adjustments Reply with quote
Sitting on her new trailer. Notice the front support piece is not high enough, the dealer said the weight is mostly in the rear and the bow roller is ok. I am questioning that the more I think about it and am going to look into raising the support. I wanted to use the boat this weekend and bet loading will be a bit of a challenge w/out the guiding the keel. Seem like the trailer needs to be back pretty far in the water for a smooth retrieve.
PostPosted: Fri Oct 16, 2020 1:34 am    Post subject: Reply with quote
no that look right. weight is mostly on the rear where the bunks are. what you want to test is the tongue weight. getting that right is important
PostPosted: Fri Oct 16, 2020 11:41 am    Post subject: Reply with quote
You want to be sure that the top of the rear bunks are flat enough for the C Dory. Generally that type of bunk is made for a deep V. I prefer flat 2 x 8 or 2 x 10 bunks, which will articulate enough to confirm to the contour of the hull, which changes in its "dead rise" from a couple of degrees at the transom to 20 or so degrees forward.. How about a photo of how the bunks fit from the rear of the boat?
Also you want either "target bunks"--one 2 x 6 or even 2 x4 on each side, near the bow, that will support the bow and direct it toward the center and align with the winch post and stop/roller near the winch. There will be little if any weight on this when you are at rest after the boat is loaded.
As it is now, you have some risk of scraping the boat on the trailer if you are off center. the forward target can be wood, tubing covered with plastic, or rollers. You don't need a lot of support forward, but you also don't want something which will not fit--and that is what you have now. The support appears to be wood, and a much deeper "V" than is present on the C Dory at that point on the bottom of the hull.
This trailer does not look like one made for a C Dory, but rather for a "deep V" hull.
gstraub
City/Region: Callao
C-Dory Year: 1998
Vessel Name: EnDoryFun
Photos: EnDoryFun
PostPosted: Fri Oct 16, 2020 1:18 pm    Post subject: Reply with quote
I have an EZ Loader trailer that looks almost identical. The tops of the bunks are angled for a deep v hull, but for a flat or almost flat hull, you simply swap the bunks (i.e. the left one goes on the right side and vice versa) and the angle is taken out of them for a flat bottom. Dealer explained that to me and swapped them and the C-Dory is well supported on the bunks. Not sure if these are the same, but likely I would bet.
Gerhard
Page generation time: 0.0385s (PHP: 43% - SQL: 57%) - SQL queries: 17 - GZIP disabled - Debug on
