Low price diesel heater
Goto page 1, 2, 3  Next
PostPosted: Thu Oct 15, 2020 1:43 pm    Post subject: Low price diesel heater Reply with quote
lowcost kmart heater
Even if it only last 2 years its worth the price.
Defiant Wally
City/Region: Phila
PostPosted: Thu Oct 15, 2020 4:51 pm    Post subject: Reply with quote
That’s interesting. Did you get it to try?
Knipet
City/Region: Orcas Island
Vessel Name: Pan-A-C'ya
Photos: Pan-A-C'ya
PostPosted: Thu Oct 15, 2020 5:21 pm    Post subject: Reply with quote
I've studied these a bit for a camper application. Complaints I've heard about these Russian & Chinese Espar knock offs are that they are quite noisy. Of course this is hearsay and not admissible in a court of law. Surprised
Steve & Joanie
2021 Venture 23 "Pan-A-C'ya
Formerly C-Sharp - 2006 22 Cruiser
PostPosted: Thu Oct 15, 2020 5:23 pm    Post subject: Reply with quote
no i have a espar, which are falling in price, and a friend wants one. So I was looking for a web site to send to him to check out the espar and wallas and found this instead. You can get these on amazon so if its a pos you do have some protection. for the price I might have my friend get one to see if it works.
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Thu Oct 15, 2020 5:46 pm    Post subject: Reply with quote
Tom there's all kinds of them up on Amazon just search diesel parking heaters. Thinking about carrying one as a spare to the Wallis for Alaska.
on edit Just saw you mentioned amazon
Jody Kidd
KE7WNG
Northern, Utah
singlecross
City/Region: DownEast
State or Province: ME
Photos: Galavant
PostPosted: Fri Oct 16, 2020 1:02 am    Post subject: Reply with quote
I'll be installing one of the Amazon Chinese diesel heaters in my 22 Cruiser next week. I'll let you know how it goes.
PostPosted: Fri Oct 16, 2020 1:36 am    Post subject: Reply with quote
that would be great. You will need a thru haul and a drain. they do not come with the kits. https://www.heatso.com/espar-eberspacher-90-degree-exhaust-pipe-adapter-24mm/
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Fri Oct 16, 2020 11:13 am    Post subject: Re: Low price diesel heater Reply with quote
I have installed 2 of these in friends boats. First one lasted 2 yrs & aprox 600 hrs. it was replaced last month, second one was installed 2 months ago they work as advertised are no more or less noisy than the Wabasto, Espar etc.. Thumbs Up
At the price they are a throw away if problems occur. Wink
tsturm
Photos: JMR-TOO
PostPosted: Fri Oct 16, 2020 12:01 pm    Post subject: Re: Low price diesel heater Reply with quote
Just a reminder if you choose to use the "muffler" that may or may not come with the China heater WELD UP THE SEAM so NO EXHAUST LEAKS INTO CABIN!! Thumbs Up
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
PostPosted: Fri Oct 16, 2020 12:20 pm    Post subject: Reply with quote
I put one in my new boat (replacing a Webasto). The old Webasto was worth enough in parts ($75) to almost cover my new heater ($99 and exactly like the one in the first post). When shopping, look closely at what is included. The muffler is generally worthless as it isn't for enclosed spaces. The air ducts are generally too short. I bought an additional "kit" that had a Y connector instead of the T connector and more 75mm air ducting. These little heaters need every bit of help you can give them.
One of the extras that came with mine was a remote. Useful for me as I can turn on the heat from the V berth without getting out of bed. Decadent. Also check the thermostat provided. Some are quite simple. Others (once you figure them out) have as many settings as a fancy home thermostat. Go to YouTube to find out how to program them. Trying to decipher the instruction booklet is wasted time.
Some other accessories that may or may not come with the kit: You will need to buy an exhaust through-hull fitting and buy or make a muffler (if you want it to be silent). Webasto/Planar, etc. have these on their websites or you can get them unbranded and cheaper on Ebay. I haven't seen a cheap exhaust muffler, so I fabricated both of mine. Another item is a silencer for the combustion air intake. It is a surprisingly loud whine and, unlike the exhaust, is generally inboard. My Webasto was originally plumbed to take in both combustion air and circulation air from outside. I eliminated that with no bad effects. Shorter runs gives better performance. I went from an 11Kw Webasto to an 8Kw "Warmtoo" brand heater with no loss in performance. In fact, I added a register in the head for more even heating of the boat.
I just added a "smart" ammeter that shows constant charge and discharge of the batteries, including available Amp Hours left. The little heater uses a glow plug to ignite (@ 9 amps for 30 seconds). On high, the fan draws 3 amps, on low (most of the time) it draws 1. When shut off, it heats up the glow plug again, shuts off the fuel, and increases the burner fan speed. This is supposed to burn out any accumulated carbon from the heater running at low speeds for hours, which tends to be the biggest complaint on "old school" diesel heaters. So far, so good.
PostPosted: Sat Oct 17, 2020 1:41 am    Post subject: Reply with quote
I'm curious how these heater compare with the Wallas 1300. I have been using my Wallas Cooktop for a heater mostly, since I have had the boat and am considering a Wallas 1300 for heat now.
PostPosted: Sat Oct 17, 2020 6:25 pm    Post subject: Reply with quote
Harvey, I believe that the Wallas cooktop is a max of 6600 BTU, The Wallas 1300 is about 4200 BTU The ones like the Wabasco or these Chinese knock offs, give 8,000 BTU. Any of the heaters with blowers and hot air circulation will heat the boat far better than the stove top, because of better distribution of heat.
The Wallas 1300 will be considerably quieter than the Chinese units.
PostPosted: Sat Oct 17, 2020 9:11 pm    Post subject: Reply with quote
Thank you Bob. I figured it would be a better heat source - one machine, one purpose -- but didn't think about it being quieter.
Would they both be able to run off of the same fuel tank, same fuel?
PostPosted: Sat Oct 17, 2020 10:39 pm    Post subject: Reply with quote
My experience is that the Espar type of heaters need a small fuel pump. They could burn kerosene, but generally are made for # 2 diesel. (#1 Diesel is basically kerosene) There are many instances of folks burning kerosene in the Espar and similar heaters, with no issues.
I would have separate fuel tanks. I would check the fuel levels independently, to be sure you don't run out at a critical time. It can be a bear in the middle of a cold night to re prime a Wallas stove... Having an external pump makes it much easier in an Espar or similar.
PostPosted: Sat Oct 17, 2020 10:45 pm    Post subject: Reply with quote
Just curious, why folks get all upset about Chinese tires, but recommend Chinese heaters? Personally, I'd stick with the Webasto over the Chinese knockoffs. I realize the Webasto (actually made in Germany) cost quite a bit more. But you are putting a little box with hot fire inside your boat. I'd much rather go with a trusted and proven unit. They have been very reliable for me in both Midnight Flyer, and my newest unit I installed in C-Traveler. Just my two cents. Colby
Page 1 of 3
Page generation time: 0.0556s (PHP: 64% - SQL: 36%) - SQL queries: 28 - GZIP disabled - Debug on
