TomCat Owners...Liquid tie bar
Molly Brown
City/Region: Punta Gorda
C-Dory Model: 24 Tomcat
Vessel Name: MOLLY BROWN
Photos: Molly Brown
PostPosted: Sat Sep 12, 2020 8:07 am    Post subject: TomCat Owners...Liquid tie bar Reply with quote
Took delivery of my new Suzuki 90"s and first order of business is to reinstall the steering system. The old Honda set up was with a tie bar 65" long. First issue is that the Suzi steering bracket is farther back on the motor than the old H, and has a different hole pattern.
Seastar does not have a steering bracket that will work and looking online the longest bracket I find is 7 and 5/8 long. Due to the dive platform I need at least 9".
I presented Betty with 2 options. Have custom brackets made or, like the Seastar rep suggested, go with a twinn cylinder, liquid tie bar set up. Presented with the estimated costs of each her response was to go with the liquid tie bar, and, replace the main hydraulic lines and helm too. She's a great gal! (All original equipment still in place since inservice date of July 2002)
Before I decide i'm interested in how many owners have a liquid tie bar set up, and what pitfalls, do different or details to be aware of going this route. I didn't mention other models because under 36" there many more options for a mechanical solution. Also, with my old set up those long brackets and 5+foot SS bar needed plenty of clearance in the splahwell and in certain situations really pinched all the tubing and wiring if I wasn't careful.
Advice appreciated,
James
Completed 01/2025
PostPosted: Sat Sep 12, 2020 11:55 am    Post subject: Reply with quote
James,
All of the Tom Cat 255's come with the "Liquid Tie Bar" as far as I know. We didn't have any problems. Just have to set the toe in correctly.
Molly Brown
Photos: Molly Brown
PostPosted: Sun Sep 13, 2020 10:35 am    Post subject: Reply with quote
Short and sweet Bob, thanks! Looks like i'll be joining the 21st century Very Happy
Stay safe and hope you and all the other gulf coast brats weather the storm with minimal trouble.
James
PostPosted: Tue Sep 15, 2020 2:34 pm    Post subject: Reply with quote
cat would be great with a joystick steer system were each motor turns and shifts indepently . allows the computer to walk the boat in to the slip sideways, https://www.youtube.com/watch?v=c_8fLy7W61c
BTDT
City/Region: Grand Lake Oklahoma
State or Province: OK
Vessel Name: C- Lark Wine Down
Photos: C-Lark
PostPosted: Wed Sep 16, 2020 11:01 am    Post subject: Reply with quote
Over 2500 hours on the Honda 150's and the liquid tie bar is still working well. If the motors get out of alignment I simply raise the motors and turn them to one side. I then rotate the alignment valve and the both engines align back up and I turn the valve back to its original position. This is very rare and normally happens only when I have a steering issue and air gets into the system. Since rebuilding my rear steering servos I have had zero problems.
John & Vicki Clark
C-Lark Wine Down
Tomcat 255
Molly Brown
Photos: Molly Brown
PostPosted: Wed Sep 16, 2020 11:25 am    Post subject: Reply with quote
John, when you say servos I think electrical. Are you talking about the hydraulic cylinders that bolt up to the engine?
I've been reading all the instructions and the liquid tiebar alignment process seems pretty straightforward and easy to do.
James
BTDT
Photos: C-Lark
PostPosted: Thu Sep 17, 2020 8:12 am    Post subject: Reply with quote
Yes, I should have used the term "steering cylinder" versus servo
Page generation time: 0.0347s (PHP: 62% - SQL: 38%) - SQL queries: 20 - GZIP disabled - Debug on
