1985 C-Dory Angler/ Accessing the Helms Rocker Switches
Tug
City/Region: Sault Ste. Marie
State or Province: ON
C-Dory Year: 1985
Vessel Name: Drifter
Photos: Drifter
PostPosted: Sat Aug 29, 2020 2:17 pm    Post subject: 1985 C-Dory Angler/ Accessing the Helms Rocker Switches Reply with quote
I'm am adding a new Chartplotter/Fishfinder and would like to connecting the power cable to the rear of the rocker switches. How do you access the rear portion of the rocker switch to connect the power cable. Thanks.
PostPosted: Sat Aug 29, 2020 2:52 pm    Post subject: Reply with quote
If you cannot access the switch from the V Bert (back of console, then remove the screws and pull the whole panel. Be sure and use proper fuses and good crimp fittings with marine wire, and heat shrink tubing. I find it easier to put a fuse block behind the console, and then when. you add items, they are easy to hook up.
Tug
C-Dory Year: 1985
Photos: Drifter
PostPosted: Sat Aug 29, 2020 4:55 pm    Post subject: Reply with quote
Bob thanks for the information , i will look at it again and give it another go. Tug.
Page generation time: 0.0279s (PHP: 59% - SQL: 41%) - SQL queries: 16 - GZIP disabled - Debug on
