Adhesive to secure bilge pump basket to floor ?
san juanderer
City/Region: Stanwood
C-Dory Year: 1990
PostPosted: Fri Aug 28, 2020 10:58 am    Post subject: Adhesive to secure bilge pump basket to floor ? Reply with quote
Please provide your suggestion.
I know in the past the Boatlife LifeSeal has worked so-so.
PostPosted: Fri Aug 28, 2020 11:03 am    Post subject: Reply with quote
I have used G flex epoxy from West Systems, and 5200, even though it is not recommended for plastics. I use hot glue to hold any item in place until the epoxy sets up. Life seal from boat life is good to use for screwed in bedding of plastics. But I would not use it as the "only" form of "adhesive".
Tug
City/Region: Sault Ste. Marie
State or Province: ON
C-Dory Year: 1985
Vessel Name: Drifter
Photos: Drifter
PostPosted: Sat Aug 29, 2020 5:02 pm    Post subject: Reply with quote
I just did mine in June , used Marine GOOP . It's seems to of did the job.
davidJ
C-Dory Model: 19 Angler
Vessel Name: E-Z Rider
Photos: davidJ
PostPosted: Sat Aug 29, 2020 5:39 pm    Post subject: Reply with quote
I also used goop about 8 years ago on mine. Its kinda a cross between calk and contact cement and will hold well to almost any surface. Its available at most hardware stores in the glue section.
PostPosted: Tue Sep 01, 2020 4:49 pm    Post subject: Reply with quote
I replaced my Midship bilge several years ago, and put it in with a double sided tape. It came loose, so last year I replaced that tape with Gorilla Brand double stick. It is still holding. I am planning on replacing my aft one with the same this year, to avoid the screws in to the Fiber Glass or gel coat.
Gorilla has been holding well in the places I have used it with one exception, and that was disturbed by side tension.
WeekiTiki
City/Region: Weeki Wachee
Vessel Name: Just Cruisin'
Photos: WeekiTiki
PostPosted: Thu Sep 03, 2020 11:59 pm    Post subject: Reply with quote
That's a given, still have window glued together with 5200 on my 100 plus year old bunkhouse since 1990.
Weeki Wachee
Page generation time: 0.0364s (PHP: 59% - SQL: 41%) - SQL queries: 23 - GZIP disabled - Debug on
