tiernanlaw@gmail.com
C-Dory Year: 1982
Vessel Name: NA
Posted: Sun Aug 23, 2020 11:41 pm Post subject: Transom is 65% saturated and list |
All:
I have a 1982 27' Cabin Cruiser C-Dory. I have a 130 HP Honda four stroke and 9 HP Honda four stroke kicker. I have both batteries on the back aft starboard of the boat next to the transom. The boat sits at approximately a 5 degree starboard list. The trim tabs help when running but I lose directional control when I put in too much starboard nose down trim. I get about 14 knots at 4000 RPM. I was just told the transom and forward of it at least 5 feet is 65% saturated. I have been told I need to cut out the transom, dig out the saturated glass/wood, and rebuild the back half of the deck. $20,000 for starters. I already have to pull out (leaky) the center 4 (yes four!) 20+ gallon glassed in fuel tanks. I was also told to haul the boat down to Arizona for a couple of years and let it dry out (we live in Anchorage, Ak), or put it in a heated garage for a couple of winters to take care of the saturation. Any advise if this was your boat?
Bart (tiernanlaw@gmail.com) _________________ Bart Tiernan |
Posted: Mon Aug 24, 2020 12:31 am Post subject: |
Bart, WOW, sorry you got that kind of news, but better to get it now than than to be half way across PWS and have the transom, outboard and related attachments take a trip to the deep six. Now that would be a really bad day. So, if you are going to have to pay to get it fixed by someone else, (and I get that because I would have to,) that is a huge bundle. You have one of the few 27 C-Dory Cruise Ships and they are pretty rare, so it might be worth a good repair. Towing it to Arizona and leaving it for a couple of years would dry it out, but that will cost you half of the 20K, (transport both ways or down and back twice, and storage there for 2 years,) and it will only dry it out, not fix any rot that might be there as a result of the "moisture". You will want it done right, not cheap, but it would be worth it to get several maybe not even just three, and you are not only looking for the $$$$'s but the work quality. Get references, check out the shop, and the working staff not just a service writer.
If you have the tools, equipment, place to work, the time and talent there are several boats here that have had serious rebuilds of the same order. There are guys and gals here that are fully capable of doing that work and could, or can direct you to instruction sites, both here and other places to help -- if you are of a mind to do it yourself.
Best to you as you go forward with this. I am sure you will get more responses from folks who are much more capable than I am. But this will give you some food for thought in the mean time.
SleepyC
Jack in Alaska
Joined: 17 Aug 2004 Posts: 1192 City/Region: Anchorage/Ninilchik
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
Posted: Mon Aug 24, 2020 2:46 am Post subject: boat repair |
I had the same problem in ,my 2005 C-Dory 26' ProAngler
My transom and about 2'of hull were water soaked.
After shopping around I found a company on West Diamond by the shredding co. on 801 E. 82 Blvd, Suite C-1 called ASHBREEZ boat works. 907-529-1907
ashbreezboatworks.com
They do an excellent job. They run it with a father (Prof at UAA) and his son who was trained at Port Townson., Wash.
Mine was approx $21,000, It was a bunch of cash but you either bite the bullet or cut it up with a chin saw.
Give him a visit. Call him, first.
Jack in Alaska on the HIGH TIDEii _________________ On the HIGH TIDE-II, wife Carolyn and I.....Another summer fishing on the HIGH TIDE II in the Cook Inlet at Cape Ninilchik, Alaska.
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
Bare hull & trailer sold in Nov. |
T.R. Bauer
Vessel Name: C-Whisperer
Posted: Mon Aug 24, 2020 9:24 am Post subject: |
That's terrible and I am really sorry. Cook Inlet Boats in Wasilla does nice work and they are affordable, as boats repair shops go. |
Joined: 02 Nov 2003 Posts: 21501 City/Region: Pensacola
Posted: Mon Aug 24, 2020 11:09 am Post subject: |
The Arizona trip is not any type of a Fix.. Even the heat there might not dry out the hull and transom fully.
You can do it and save well over half--probably 2/3 of the expense or let someone else do it. The issue is that the boat is 28 years old, and probably has been thru many freeze thaw cycles.
Or you might just do the transom, and keep using the boat as it is. I don't know if the 27 had a grid structure to support the transom, but you are running relatively low HP for that boat. I had a 130 on a 25, and thought it was underpowered. If the 14 knots and the 4000 RPM is max RPM, then you need a lower pitched prop to perform well. You can move the batteries to the port side, which will help some with the list. Also move any portable gear to the port side to balance. The new core will not solve the list issue.
I understand how disappointing this is, but it is not the "end of the World", or "Chainsaw time". The boat is very "fixable" and it took 28 years to get into this condition, Redo will give it another 30 years. _________________ Bob Austin
Foggy
Joined: 01 Aug 2013 Posts: 1582 City/Region: Traverse City; Northern Lake Michigan
C-Dory Year: 2014
Photos: W B Nod
Posted: Mon Aug 24, 2020 7:21 pm Post subject: |
Stuff happens.
Just sold my 2004 32' Tiara Open with "moisture problems" in which I took a
multiple $K "survey adjustment" penalty.
The good news is it is sold and no longer my problem.
The lesson is older boats can, and usually do, develop problems that can be
overlooked or not noticed until a pro does an inspection.
Diligence is a missing word in the day-to-day life of many boat owners.
Aye. _________________ Keep an open mind just enough to not let your brain fall out. |
T.R. Bauer
Posted: Mon Aug 24, 2020 9:51 pm Post subject: |
I'm with everyone else - you must cut out the wet/rot materials and repair it properly. But, Arizona is a really nice trip in the winter time if you can swing it - especially up here where winter can wear on you. |
C-Dory Year: 1982
Vessel Name: NA
Posted: Fri May 05, 2023 2:01 am Post subject: |
Thanks all for the tips. I've finally decided to tear into (demo) it myself and have the experts rebuild it. I figure I cannot do any harm so long as I am careful about cutting into the hull. I plan on cutting a hole in the top, measuring the thickness of the deck, adjusting my cirular saw accordingly (with appropriate blade), and cutting within 4 to five inches of the sides of the back deck (house back to stern). After that, I figure I will have to "wing it" with a hammer, chisel, and whatever other tool required.
If anybody has any suggestions (or believes this is the wrong POA), I'm all ears....especially about specialty tools or things to pay attention to unique to the 27' CDory.
Thanks in advance,
Bart |
Joined: 07 Nov 2003 Posts: 7937 City/Region: marysville
Posted: Fri May 05, 2023 12:47 pm Post subject: |
I have a 27 also with an alum hull extension and a 225 honda and a 15hp kicker. Does your 27 have the long cabin with the head at the rear of the cabin? There were at least 4 versions of the 27 and they only made between 10 and 20 boats total. You have 4 fuel tanks you said and I only have 2 50s that run just behind the cabin from port to starboard. I have one big hold under the deck but some boats had 2 smaller ones, which do you have? would love to see pictures of the boat.
When I first got mine I have water getting in and sitting on the tanks and under the tanks. The side cabin wall had came loose from where it attached to the hull. You could not see it but the rain would seep thru and end up on the tanks. I could not remove the tanks but I did have to replace the rear wall of the cabin ( wood) and build a new one. I pulled the covers for the tank and the fill hoses and spent a week vacuuming out the water and soaked foam followed by a heat gun or vaccum in reverse blowing into the tank area for a week. I also have to under cut and re epoxy the deck above the tank where the port was for the fuel pick ups and site gages.
I have often wondered if I have any rot from that time but its been ten years and the boat is stored out side but under cover. Please take lots of photos of your project. think about adding a hull extension, not a offshore bracket and new motors. have fun. _________________ Thomas J Elliott
tsturm
Joined: 01 Nov 2003 Posts: 1172 City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Fri May 05, 2023 8:06 pm Post subject: |
T.R. Bauer wrote: | That's terrible and I am really sorry. Cook Inlet Boats in Wasilla does nice work and they are affordable, as boats repair shops go. |
X2 on Cook Inlet Boats! |
C-Dory Year: 1982
Vessel Name: NA
Posted: Fri May 05, 2023 10:40 pm Post subject: |
Not sure how to upload photos.
Bart |
Posted: Sat May 06, 2023 4:12 am Post subject: |
Ask TyBoo or Da Nag for an album. They are number 2 and 3 on the "member list" in the header above.
Once you have your album, there will be a "add Photo" link on the first page of the album. Click on that, and then follow instructions. Be sure that any pop up blocker is off.
To transfer to the threads, click on the photo in your album , and then push "Control" on the MAC, (or right click on the windows?) and get image address (ends in jpeg). Raw photos will not upload. Although the site can compress the photo, if it is large as mine usually are, then you may want to compress the photos, to jpeg.
Place the photo address between the "[img]" and "[/img/".
I use a MAC so Windows may be slightly different. |
C-Wolfe
Joined: 16 Sep 2020 Posts: 343 City/Region: Anchorage
Vessel Name: Valhalla
Photos: C-Wolfe
Posted: Tue May 09, 2023 3:27 pm Post subject: |
Did you just put up your boat for sale? _________________ Stephan
Sculpin; Drascombe Drifter 2005-2008 |
T.R. Bauer
Posted: Wed May 10, 2023 10:42 am Post subject: |
C-Wolfe wrote: | Did you just put up your boat for sale? |
There is, or was one similar up her for sale....good question. It did disappear as a listing and the description was spot on. I'm not sure an old boat without power and needing a ton of work has very much value - even our beloved C-Dory boats. I know I wouldn't take it on as I'd rather be boating than working on one. It's a terrible spot to be in as an owner and I feel bad for him. |
C-Wolfe
Photos: C-Wolfe
Posted: Wed May 10, 2023 11:52 am Post subject: |
I also assume it is the same. I message to the one for sale here and it is sold. I would like that boat but have nowhere near the time to tackle that kind of project. It appear that he was in a similar position. |
