PWM on the windlass circuit?
clayhubler
City/Region: La Center
Vessel Name: Hammerhead
Photos: Hammerhead
PostPosted: Tue Aug 25, 2020 3:33 pm    Post subject: PWM on the windlass circuit? Reply with quote
I want to be able to slow the windlass down for the final retrieval to get it into the bow roller without bouncing all over and slamming into the bow. Has anybody used a pulse width modulation controller for this purpose? Any reason not to go ahead with it?
Clay on Hammerhead
PostPosted: Tue Aug 25, 2020 8:49 pm    Post subject: Reply with quote
I have not used one in this application. You want at least 60 amp capacity unit. --(probably in reality 100 amps better because you need to be able to briefly supply locked rotor capacity current). bypass unless you are using it in the last few feet. I use short bursts of the Up switch. You are working thru relays--with most of the switches-
I would put the control unit after the relay and have a bypass switch (which has to also be able to handle the load). How much current draw will there be as you drop the voltage to get the motor moving when under load? (of course these are all relatively small motors geared down, so there is some inertia in the system.)
Let us know how it works out. I see where people have talked about doing it, but no place where it was done.
If you went before the relay, I would fear relay burn out, from rapid open and closing of contacts.
Page generation time: 0.0272s (PHP: 48% - SQL: 52%) - SQL queries: 21 - GZIP disabled - Debug on
