Need help YAMAHA 50 hp part identification
KevinDU
Vessel Name: Sea Otter
Photos: Sea Otter
PostPosted: Sat Aug 08, 2020 2:42 pm    Post subject: Need help YAMAHA 50 hp part identification Reply with quote
I just took the hood off my Yamaha 50 hp and found a loose part in the bottom of the engine just below the air intake. I have twins and looked for the part in the other engine but I cannot find it. Does anyone know what this is? Thanks in advance!
http://www.c-brats.com/modules.php?set_albumName=Sea-Otter&id=IMG_9704&op=modload&name=gallery&file=index&include=view_photo.php
http://www.c-brats.com/modules.php?set_albumName=Sea-Otter&id=IMG_9705&op=modload&name=gallery&file=index&include=view_photo.php
KevinDU
Photos: Sea Otter
PostPosted: Sat Aug 08, 2020 4:23 pm    Post subject: Reply with quote
I found the same loose part in the bottom of the other engine, just below the air intake. Motors are running fine, should I be worried about it? I can't figure out where this plastic piece was attached.
PostPosted: Sat Aug 08, 2020 6:19 pm    Post subject: Reply with quote
Did you check the hood itself?
PostPosted: Sat Aug 08, 2020 7:20 pm    Post subject: Reply with quote
I have no idea what that strip is, but those 2 tits are fasteners into 2 holes. look over the hood and engine compartment until you find the matching holes.
I realize you probably already did this. I have to make some comment.
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Sat Aug 08, 2020 10:08 pm    Post subject: Re: Need help YAMAHA 50 hp part identification Reply with quote
6C5-42718-00-00 Google this yamaha part# it will be # 8 in the pict
Thumbs Up
DayBreak
City/Region: Monmouth, Or.
C-Dory Year: 2018
Vessel Name: DayBreak
Photos: DayBreak
PostPosted: Sat Aug 08, 2020 10:58 pm    Post subject: Reply with quote
Oops, I had said to go to brownspoint.com to look at a parts diagram. I now realize that they only specialize in Suzuki parts. If I come across a Yamaha parts dealer I will let you know. Looking at a parts diagram should help you to determine where that component came from. I would start by looking at Yamaha parts dealers on-line to remedy this problem.
KevinDU
Photos: Sea Otter
PostPosted: Sun Aug 09, 2020 1:02 am    Post subject: Reply with quote
Thanks, tsturm! I found a parts diagram and will look into it tomorrow.
Page generation time: 0.0489s (PHP: 63% - SQL: 37%) - SQL queries: 24 - GZIP disabled - Debug on
