Prop Oil seal test pressure
SnowTexan
City/Region: Carlton
Vessel Name: Miss Maria
Photos: Miss Maria
PostPosted: Mon Aug 03, 2020 10:06 pm    Post subject: Prop Oil seal test pressure Reply with quote
So I pulled my lower unit to swap out an impeller and decided to pull the prop and inspect the seals. The outer seal looked terrible. I am a long way from any marine mechanic and do not have the proper tool to remove the prop shaft so I did the 5th or 6th best thing: i picked the worn seal out with a screwdriver (taking care not to scratch the shaft and shred the replacement shortly after installation). The inner seal looks great, and I performed a leak test using my dingy hand pump and some gorilla tape. Yeah thats right all you professional mechanics you read that correctly 😂. I left the inner seal after seeing no air bubbles escaping with a soap and water mix. Replaced outer seal. Best I can do under the circumstances but my question is this: when a shop tests for leaks how much pressure is used? The quest for self reliance continues via reliance on cbrat wisdom.
Thanks!
Nigel
PostPosted: Mon Aug 03, 2020 10:50 pm    Post subject: Reply with quote
12 PSI, and should keep the pressure for 5 minutes. It is tested thru the upper port. The soapy water does a good job. You should be good to go.
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Mon Aug 03, 2020 10:56 pm    Post subject: Reply with quote
Thumbs Up What Bob said Thumbs Up
SnowTexan
Photos: Miss Maria
Alright thanks sir! Is it normal
For the prop to be a little stiffer at first after what i’ve done?
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Tue Aug 04, 2020 12:04 pm    Post subject: Reply with quote
I'd expect that since you actually have a seal now. Good Job Smile
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Tue Aug 04, 2020 12:25 pm    Post subject: Reply with quote
Something that is best practice, is to always pull the prop and related washers at each oil change period. This allows a good inspection of the propeller blades, ensures that the prop does not freeze up on the shaft, so that it can be changed in the future, allows a visual inspection of the seal and most of all, you get to ensure that there is no fishing line wrapped forward of the prop, chewing away the shaft seal.
You can true up the prop as needed with a block of wood and a ball pen hammer (minor dings) and you can use a file to clean up any burs.
When reinstalling the prop, lubricated the prop shaft and washers with a waterproof grease (synthetic Green Grease for your local auto store is great for this) place a small piece of 2x4 wood between the prop and the underside of the anti-cavitation plate. This will allow you to tighten to prop and align the nut to except the cotter pin.
Steve Baum
Homeport of Portsmouth, VA
SnowTexan
Photos: Miss Maria
PostPosted: Tue Aug 04, 2020 2:36 pm    Post subject: Reply with quote
Hah! Yes that occurred to me shortly after posting. Thank you all for the replies.
Page generation time: 0.0655s (PHP: 38% - SQL: 62%) - SQL queries: 20 - GZIP disabled - Debug on
