Two kinds of boaters: liars and those who've run aground
Goto page Previous  1, 2, 3
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Mon Aug 03, 2020 1:16 am    Post subject: Reply with quote
You don't have to reshim if you keep track of where the shims went Smile
PostPosted: Mon Aug 03, 2020 12:07 pm    Post subject: Reply with quote
I assumed a different drive shaft. I also assume that it'll need different shims. And, I assume those shims make up for different tolerances. If I'm wrong, you're correct.
I do know that when I had the differential rebuilt on my truck, they were careful to shim it so it had the right contact pattern between the gears. I would think the same applied in outboards.
Page 3 of 3
Page generation time: 0.0424s (PHP: 30% - SQL: 70%) - SQL queries: 20 - GZIP disabled - Debug on
