curioustraveler
Joined: 26 Apr 2019 Posts: 211 City/Region: Annapolis
State or Province: MD
Photos: Curioustraveler
Posted: Tue Jul 07, 2020 8:44 pm Post subject: Removing rust spots |
I've developed small rust spots all over my sink (size of a dime and smaller). Also seems to be some starting on my stove. Any idea what could be causing these? Just the humidity? I keep windows cracked and DampRid in the cabin but it's Maryland in July so the humidity is what it is.
Any idea how to clean this and also how to prevent it?
Thanks |
easy does it
Vessel Name: Pura Vida
Photos: Easy Does It
Posted: Wed Jul 08, 2020 7:03 am Post subject: post topic |
"never dull" is incredible stuff and a can will last you for years |
tsturm
Joined: 01 Nov 2003 Posts: 1134 City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Wed Jul 08, 2020 9:36 am Post subject: Re: Removing rust spots |
curioustraveler wrote: | I've developed small rust spots all over my sink (size of a dime and smaller). Also seems to be some starting on my stove. Any idea what could be causing these? Just the humidity? I keep windows cracked and DampRid in the cabin but it's Maryland in July so the humidity is what it is.
Thanks |
Barkeepers friend is perfect for this |
Posted: Wed Jul 08, 2020 11:44 am Post subject: |
Generally for rust spots, I use Bar Keeper's friend. The main ingredient is oxylic acid. There are waxes for SS, which work well. I also use Corrosion block, or Corrosion-X _________________ Bob Austin
Foggy
Joined: 01 Aug 2013 Posts: 1519 City/Region: Traverse City; Northern Lake Michigan
C-Dory Year: 2014
Photos: W B Nod
Posted: Wed Jul 08, 2020 1:55 pm Post subject: |
Surprisingly, for a bunch of boaters, the obvious solution not yet
recommended for removing rust is, of course, Naval Jelly.
Perhaps it came to mind quickly for me since I spend considerable
time there, contemplating...
Aye. _________________ "I don't want any cake" - said no one ever.
If someone tells you they don't eat cake, unfriend them. You don't need that kind of negativity in your life. |
Posted: Wed Jul 08, 2020 9:41 pm Post subject: |
Foggy wrote: | Surprisingly, for a bunch of boaters, the obvious solution not yet
Aye. |
Instructions for using Naval Jelly; (Which I have used when appropriate.)
Quote: | Apply naval jelly liberally to the rusted metal with a brush, working it into crevices and pits carefully. ...
Let the product work for at least 15 minutes or longer for heavy rust.
Rinse it off with water and check for residual rust. ...
Prime and paint the surface within 24 hours.
Another question I would ask:
Is this rust on the surface--such as you might see from use "steel wool", or does it seem to be in the structure of the SS itself? We have high humidity and don't seem to have any major rust problems with the sinks or stove. |
curioustraveler
Posted: Wed Jul 08, 2020 10:38 pm Post subject: |
It just seems to be on the surface. I think what caused it is my wife spilled some DampRid into the sink. It probably sat in there for a few days. When I wiped it up I noticed some rust where the DampRid was.
I believe we have some Bar Keepers Friend so I'll try that. If it doesn't work, I'll get some Nevr Dull. |
Posted: Thu Jul 09, 2020 10:08 pm Post subject: |
Ah, Ha....Calcium Chloride is the ingredient in "Rid Damp". It is corrosive to SS alloys. That is your answer.
If you want the most effective way to lower humidity: use a powered dehumidifier. I have a couple of marine "Mighty Dry" units; they are no longer made. But any cheap WalMart type of dehumidifier will work well enough. Put the discharge hose thru the galley sink drain. The disadvantage of these is that they increase the temperature in the boat. An open window is great for air circulation--but may defeat the attempt to decrease the humidity. |
curioustraveler
Posted: Thu Jul 09, 2020 10:31 pm Post subject: |
Thataway,
Thanks for the info. Hopefully bar keeper's friend will work on in. Good to know the cause, it's not just humidity.
I assume the dehumidifier you mentioned requires AC power? Unfortunately I don't have shore power at the slip.
I keep a few windows cracked and she's actually stayed quite dry. My previous sailboat cabin constantly struggled with mildew. Between the v-berth and pilothouse hatch and the side windows, I think it stays quite ventilated. I also keep some Kanberra gel in there. |
Posted: Fri Jul 10, 2020 12:19 pm Post subject: |
I suspected that you didn't have power. Ventilation certainly helps. We have several solar powered vents, which keep the air circulating in and out.
Are the windows under protection so rain doesn't intrude?
I have also experimented with some small ozone generators, which have timers. Seems very effective. I have not used any of the 12 volt units however. |
WeekiTiki
Joined: 12 Jun 2019 Posts: 412 City/Region: Weeki Wachee
Vessel Name: Just Cruisin'
Photos: WeekiTiki
Posted: Fri Jul 10, 2020 4:51 pm Post subject: |
Certainly don't recommend putting acid on stainless but...
Thirty years ago I had my boat hauled and there was a Morgan Sailboat nearby. Dude worked for weeks trying to rid the stern from rust stains. Finally told him for $100 I'd clean his transom. Should have seen his face when I sprayed it with Muriatic Acid and the whole stain melted away. _________________ Weeki Wachee
curioustraveler
Posted: Fri Jul 10, 2020 10:55 pm Post subject: |
Bar Keeper's Friend worked great.
I've looked at installing some solar powered vents but so far, leaving the windows and hatches cracked open seems to work fine. Even in some heavy downpours we haven't gotten water in the cabin. (except through the seals on the cabin door...but that's a question for another thread.) |
