Johnc_3
C-Dory Year: 1998
C-Dory Model: 24 Tomcat
Vessel Name: White Knight
Posted: Tue Jun 16, 2020 3:30 pm Post subject: Twin engine, Match fuel consumption or RPM |
So I have a 24' TomCat with twin Mercury Command Thrust 115hp Out board engines, starboard engine is counter rotating. I use Mercury VesselView mobile for electronic engine feed back. When on step I usually match RPM but noticed the counter rotating (starboard) engine uses a lot more gas than the standard rotation (port). My son says just match the fuel consumption when trimming the engines. That works and fuel consumption matches but... That doesn't seem the proper way to trim the boat. Anyone have any reasons why the counter rotating engine uses more fuel? And what is the recommendation for trimming out the engines? fuel consumption or RPM? |
Joined: 27 Oct 2012 Posts: 3581 City/Region: SW Michigan
Posted: Tue Jun 16, 2020 4:35 pm Post subject: Re: Twin engine, Match fuel consumption or RPM |
Johnc_3 wrote: | So I have a 24' TomCat with twin Mercury Command Thrust 115hp Out board engines, starboard engine is counter rotating. I use Mercury VesselView mobile for electronic engine feed back. When on step I usually match RPM but noticed the counter rotating (starboard) engine uses a lot more gas than the standard rotation (port). My son says just match the fuel consumption when trimming the engines. That works and fuel consumption matches but... That doesn't seem the proper way to trim the boat. Anyone have any reasons why the counter rotating engine uses more fuel? And what is the recommendation for trimming out the engines? fuel consumption or RPM? |
I would start with "Are the fuel flow counters calibrated correctly?" You might run the engines off separate tanks and see if the fuel used matches the fuel consumed numbers. |
Johnc_3
C-Dory Year: 1998
Posted: Tue Jun 16, 2020 4:38 pm Post subject: Twin engine, Match fuel consumption or RPM |
we do have separate fuel tanks and indeed when matching rpm the counter rotating outboard uses more fuel.
The Mercury electronic Vessel View uses the on board computer in each engine for RPM and fuel consumption feed back. |
Joined: 02 Nov 2003 Posts: 21478 City/Region: Pensacola
Posted: Tue Jun 16, 2020 5:48 pm Post subject: |
Is the gear ratio different in the counter rotation? This is sometimes the case. I don't know about Mercs. _________________ Bob Austin
Johnc_3
C-Dory Year: 1998
Posted: Tue Jun 16, 2020 7:02 pm Post subject: |
Gearcase ratio 2.38:1 is what is listed for both lower units. So should be the same. I wouldn't think there would be much loss in gearing to reverse rotation. |
gulfcoast john
Joined: 14 Dec 2012 Posts: 1044 City/Region: PENSACOLA
C-Dory Year: 2010
Vessel Name: Cat O' Mine
Photos: CAT O' MINE
Posted: Tue Jun 16, 2020 7:31 pm Post subject: |
I run Yamaha 150’s but the hull is the same. Engine info is on the N2k backbone (I’m not aware of any other TC255 owner with this setup). MPG and GPH display as analog gauges, so it’s not easy to see trivial differences under 15%.
Official YamaWorld pronouncement is that if 2 consecutive engines built by the same girl on the same day on the same assembly line differ in fuel use by 15% that is NORMAL. (We don’t find this on the all-robot Porsche Panera assembly line for a reason).
Likewise, They pronounce that any counterrotater will consume MORE fuel, but not how much more or why. If 15% is NOTHING, maybe 30% more could be expected.
My understanding (perhaps wrong) is that automated engine ‘synchronizers’ on large boats synchronize RPM’s, not fuel consumption. I tend to synch manually by RPM, but my fuel consumption per engine is within 15-20% (14 GPH is within 15% of 16.1 GPH, which I now regard as trivial. 14 GPH for #1 vs 16.8 GPH for the counter rotator would only be a 20% difference).
Is your variation around this same 15%?
I see no harm in following your son’s rec’d to synch by fuel consumption, as long as you chill out for differences in the 15-20% range and chalk it up to another of the Mysteries this Universe is entitled to have, with or without us.
It all seems more art than science.
Enjoy your boat! My VesselView experience was that if the engine computer didn’t shut ‘em off, it’s all Good and nothing to worry about.
Cheers!
2010 Tom Cat 255, Cat O' Mine
Yamaha F150, LXF150 |
Posted: Wed Jun 17, 2020 11:10 am Post subject: |
Johnc_3 wrote: | Gearcase ratio 2.38:1 is what is listed for both lower units. So should be the same. I wouldn't think there would be much loss in gearing to reverse rotation. |
Some engines have an extra gear to reverse.--and this maybe true in engines with same gear ratio-- which will add more friction. Long time ago some outboards were run "backward" (counter clockwise) for the counter rotating engine.
Incidentally your engines are set up properly for a cat, with the counter rotating on the Starboard side--the reverse of what is recommended for monohulls.
The engines should be synced for RPM--and prop thrust. For example in some boats with different ratios, different pitch props will be used to give same RPM.
I agree with John, it would be interesting to run curves to see exactly how much extra fuel the engine is burning at different RPM. Info from the engine computer should be accurate. I have computers on my trucks which give "current" fuel contusion in gallons per hour. At the same RPM, it can vary depending on load.
Would there be more load on the counter rotating engine? I don't think so--but for example if there was more fouling on that hull it might give that effect (and I doubt that there is any fouling...Just an example. |
BTDT
Joined: 07 Jan 2011 Posts: 322 City/Region: Grand Lake Oklahoma
State or Province: OK
Vessel Name: C- Lark Wine Down
Photos: C-Lark
Posted: Wed Jun 17, 2020 11:14 am Post subject: |
Sounds clear as mud to me
On my Tomcat 255 the starboard Honda 150 consistently uses more fuel than the port counter-rotating motor. Best guess is an average of 10% fuel usage.
As a long time pilot I prefer to match engine RPM's over fuel flow. Do you not sometimes hear slight propeller cavitation when matching fuel flow versus prop rpm? _________________ John & Vicki Clark
C-Lark Wine Down
Tomcat 255 |
