Rattle in Fuel Tank
Forfun1960
City/Region: Carmi
State or Province: IL
Vessel Name: Journey former Noro Lim
Photos: Journey
PostPosted: Thu Jun 04, 2020 9:48 am    Post subject: Rattle in Fuel Tank Reply with quote
I have a 23' Cape Cruiser with 2-30 gallon Aluminum fuel tanks. The port tank has an intermediate rattle inside the tank. Seems like it is mostly at idle. Rattle takes place no matter which tank I am using. Wonder if anyone has seen or heard of this issue before? Not sure where to do anything about it or not boat runs find.
Donnie Wilson
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Thu Jun 04, 2020 11:54 am    Post subject: Re: Rattle in Fuel Tank Reply with quote
If it bothered me I would drain it pull it out & see what it is & if I can't get it out?
Or maybe a weld on a baffle is broken & needs to be repaired?
Cap from a additive can? Wink Thumbs Up Or is there something laying on top (or out of sight) vibrating at idle?
Good luck & let us know.
CC Rider
City/Region: Tsawwassen
Vessel Name: CC Rider
Photos: CC Rider
PostPosted: Thu Jun 04, 2020 3:19 pm    Post subject: Reply with quote
I too have a 2006 Cape Cruiser and both of my tanks have made this noise since I have owned her. I had a problem with my engine once, and thought it may have been a plugged fuel line pickup and so I removed the pickup and had a look to find nothing in the tank. And by the way, there is no filter on the end of the pickup tube...
The noise is strange, it only happens at engine idle, and only when I first start either the main or the kicker. (Both engines are connected to the tank(s).) I have come to the conclusion that it is either the fuel gauge floats that cause this, or more likely a little air in the pickup line is making the noise.
Chris
MMSI#: 316033635
PostPosted: Thu Jun 04, 2020 5:14 pm    Post subject: Reply with quote
Couldn't also just be resonance somewhere? There are things on my boat that resonate depending on engine RPM.
CC Rider
Photos: CC Rider
PostPosted: Thu Jun 04, 2020 6:53 pm    Post subject: Reply with quote
Forgot to mention that there is a check valve with a small ball bearing located at the elbow at the top of the tanks. Now that I think about it, this is the most likely culprit as the ball probably rattles back and forth with low fuel flow (at idle), but not when the flow is greater (anything above idle).
Chris
Forfun1960
City/Region: Carmi
Photos: Journey
PostPosted: Thu Jun 04, 2020 8:40 pm    Post subject: Reply with quote
Thanks Chris, Glad to hear others have a similar situation without issue. This winter I might pull the tank to satisfy my curiosity.
Page generation time: 0.024s (PHP: 62% - SQL: 38%) - SQL queries: 19 - GZIP disabled - Debug on
