Will Raymarine Autopilot talk to a Garmin?
Easyvictor.14
City/Region: Dallas
State or Province: TX
Vessel Name: Easy Victor
Photos: Easy Victor
PostPosted: Mon May 25, 2020 6:50 pm    Post subject: Will Raymarine Autopilot talk to a Garmin? Reply with quote
I have a full Ray Marine C80 set up with auto pilot and radar. My question is, if I want to put in a Garmin chart plotter will my Ray Marine auto pilot work with it? I’m assuming it’s in NMEA 2000 and will be compatible?
2008 23 Venture, 2008 Raymarine package.
"New" 2008 23 Venture.
1992 Boston Whaler Montauk 17
1977 Sea Ray SRV 200 sold 2008
1981 T Craft 26 center console
1981 Silverton 34
1979 Chapparal 187
Many, many other small aluminum, wood and fiberglass toys!!!
PostPosted: Mon May 25, 2020 7:10 pm    Post subject: Reply with quote
What pilot do you have? I suspect it may talk to the Garmin with NMEA 0183, but there is enough difference between the Sea Talk of an older pilot and current Garmin it may not. However you can keep the C 80 for just the pilot.
I have the RayMarine Axiom 9 (touch screen only) and 7 (hybrid touch and dial/button) MFD, which work perfectly with my older RayMarine Pilot (probably 20012 vintage). They are good units, but maybe not as intuitive as the Garmin. However they do run Navionics charts which I prefer.
See: Here and Here,. You may be able to do the connection with a converter:
PostPosted: Mon May 25, 2020 10:21 pm    Post subject: Reply with quote
Will a Ford talk to a Chevy? Mr. Green For a while I had a cheap Raymarine autopilot and two Garmin Chartplotters. I used the Seatalk backbone and had an adaptor to add the Garmin Chartplotters in the loop. For some reason, the raymarine always wanted to work with the GPSMAP 541 over the GPSMAP 840. I had to leave the route off of the 541 if I wanted the 840 to be in control. The raymarine would only follow routes. It would not follow tracks or autorouting. And even with a route on the chartplotter, at each and every turn the Raymarine a/p would start warning me to hit the connect button again, otherwise it went into heading hold. In other words, a PITA to use for route following with the Garmin! Colby
Page generation time: 0.0575s (PHP: 31% - SQL: 69%) - SQL queries: 17 - GZIP disabled - Debug on
