Fishwisher’s core rot removal
Teufelshunde
City/Region: Sebastopol
Vessel Name: Fish Wisher
Photos: Fishwisher
PostPosted: Mon May 18, 2020 9:20 pm    Post subject: Fishwisher’s core rot removal Reply with quote
I didn’t want to hijack Jackie’s thread so I started my own - seems like there is a lot of us fixing rotten balsa as of late!
I posted pictures in my album today as to what I have found so far under my port side fuel tank and plan on exploring the starboard side tomorrow and will probably find the other half of the detour (see pictures and you’ll get it) it’s amazing what some people think is a good idea!
I was surprised to find that my core is 1-1/2 thick I thought it would be 3/4. My question is - does anyone know where I could source the core replacement and also what grade of end grain balsa?
I am planning on replacing with balsa unless there is a better recommendation? I need to be able to over drill and epoxy the holes to secure the tank when repairs are completed.
Any thoughts, ideas or comments appreciated,
Fish on!
What ever you are, be a good one 🇺🇸
Barry Rietz
City/Region: Sierra Vista
PostPosted: Mon May 18, 2020 11:06 pm    Post subject: Rotten to the Core Reply with quote
Teufel, Nice job on both the boarding ladder install, and the rot repair found in the forward hatch area. Apparently at the time of the build, the factory used two layers of 3/4" end grain balsa as shown in your photos. Once you have assessed the starboard side I would obtain a moisture meter and check the balsa that remains and "appears" to be free of moisture. If there is no moisture observed, I would nevertheless dry this area using heat lamps before going forward. If it were my project, I would source "Airex" or "Kledgacell" closed cell rigid foam in the highest density available and use epoxy to secure the patch. The "foam" will never absorb water and will provide a nice base on which to add the final "glassmat" laminate, again using epoxy resin.
Barry Rietz
N9DXC
Jackie
City/Region: Ketchikan
Vessel Name: Lil' Bit
Photos: Lil Bit
PostPosted: Tue May 19, 2020 12:28 am    Post subject: Reply with quote
Teufelshunde, I so feel your pain. At least you found the edges - everytime I cut further I uncover a big area of water. Soon I'll have everything removed!
I also have a 1.5 inch core and found that a product called CoreLite comes in thicknesses up to 4 inches. I haven't priced it. It's in Miami and shipping to Alaska probably won't be cheap. If you find anything closer, let me know. I'll also keep looking.
Your user name made me wonder if you were in the Marines?
PostPosted: Tue May 19, 2020 7:10 pm    Post subject: Reply with quote
I wonder how many of the boats had 1 1/2" thick cores? You can make balsa as thick as.you want. My very close friend's 55 foot boat was entirely Built of balsa planks, fiberglass inside and out. He made 3 circumnavigations--no problems. Also hit a mostly submerged container (at the corner) at 8 knots when racing off Mexico--no water intrusion and we sailed several hundred miles back "Home"...
You are going to have to have some kerfs to get the flexibility to follow the hull contour. Ideally all of the kerfs should be filled with resin. Usually one side has a layer of mat on it to hold the scrim together. If laying up with polyester resin, you will put a layer of mat on top before the 1708.. If epoxy, then probably a layer of thin cloth, or mat designed for epoxy on the top and saturate the core with the epoxy. Epoxy is stronger and better adhesion with secondary bond. But it is considerably more expensive. Doing in essence the whole boat polyester makes more sense.
You can either use the 1 1/2" thick material. and only a few places carry bales core more than 3/4" thick. Or you can use two layers of the 3/4", with light mat between, saturated with resin.
When you lay the balsa on the inside of the boat cutter skin, you will want to trowel on resin thickened with cabosil to fill any voids on the inside of the floor. Use a notched trowel as you would laying ceramic tile.
Teufelshunde
Photos: Fishwisher
PostPosted: Wed May 20, 2020 11:45 pm    Post subject: Reply with quote
Jackie,
I found a place in Colorado that can do 1-1/2 Balsa and am expecting a response in a few days for a price (I think it’s pretty pricey but we’ll see).
Yes I was in the U.S. Marines from 94-2001 as a Longshoreman and a “PMI” (marksmanship instructor).
Teufelshunde
Photos: Fishwisher
PostPosted: Thu May 21, 2020 12:04 am    Post subject: Reply with quote
Bob,
It sure didn’t seem that the balsa I removed had any type of separation or resin filled kerfs (if my understanding is correct as to kerfs) under the fuel tanks.
There is a very slight curve from outside edges to center of boat aft. but I plan on saturating the new core in un-thickened epoxy for sure.
I have been reading the west systems epoxy manual and watching their you tube tutorials which are helpful - it also has been a better understanding for me as I used to do body and paint work for a few body shops in the late 80’s into the early 90’s but little fiberglass work,I appreciate your knowledge thank you.
Teufelshunde
Photos: Fishwisher
PostPosted: Thu May 21, 2020 12:14 am    Post subject: Re: Rotten to the Core Reply with quote
Thanks Barry I’m currently researching and appreciate your thoughts - I definitely cut back far enough to hard core material and it’s been in the 70’s here so I’m letting it sit in the sun for the next few days to make sure everything is bone dry.
If the balsa is too pricey I’m going to look into the “foams” further.
Thanks again.
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
PostPosted: Thu May 21, 2020 10:10 am    Post subject: Reply with quote
As I recall, I looked around and C-Dory in Bremerton was the easiest and quickest supplier (for me). Although I found it cheaper elsewhere, the time/money of of shipping a 2x4" piece of 3/4" balsa was crazy (the box would weigh more than the contents). I took a leisurely drive to Bremerton (a lesser waste of time/money?) and paid $75 for a piece. I drove back on Chuckanut Drive and stopped at Baskin Robbins in Mount Vernon to make it a proper joy ride.
Jackie
Photos: Lil Bit
PostPosted: Thu May 21, 2020 2:35 pm    Post subject: Reply with quote
Teufel, please keep me informed on the Colorado supplier when you find out the cost. I contacted CoreLite and their 1.5" only comes in rigid sheets. I'm thinking Bob's suggestion of two layers of 3/4 inch might work best for me as I have a pretty good curve to fill in the bow. The wide openings of the kerfs as they curved there (and weren't filled) definitely added to the water migration. 3/4 inch wouldn't open so wide and would be easier to fill.
I don't think switching to a balsa alternative would work for me. I rounded the numbers up for safety, but I have about 28 square feet of core removed! I don't want to mess with different stiffnesses in the core so had better stick with matching my materials.
I will call C-Dory in Washington as it would be easiest for them to ship to the barge. Anything big is best barged to me.
Good luck as you keep at it! I spent three years in Germany during my service time. I was in the Army from 1976 - 1981.
Barry Rietz
PostPosted: Thu May 21, 2020 11:26 pm    Post subject: Rotten to the Core Reply with quote
This company has a comprehensive list of balsa and foam core materials in smaller size panels that would suit your application:
http://www.fiberglasssupply.com/
Moxieabs
City/Region: Cape Neddick
State or Province: ME
Vessel Name: Widget
Photos: Widget
PostPosted: Fri May 22, 2020 9:43 pm    Post subject: Reply with quote
Jackie,
Unrelated to balsa core, but I was in 3rd Armor, Hanau '76-80. Where were you?
Moxieabs on WIDGET
Teufelshunde
Photos: Fishwisher
PostPosted: Sun May 24, 2020 6:39 pm    Post subject: Reply with quote
30”x30” x1-1/2 inch thick is $165 + shipping - I need two of that size so the cost is $395 Shocked then I saw Barry’s post today and put a call into the supplier he suggested ( thanks Barry). I also posted pictures of the second half of the detour on the starboard side in my album.
We will see how it goes!
PostPosted: Sun May 24, 2020 11:04 pm    Post subject: Reply with quote
At that price I would go with two 3/4" pieces--just put a layer of mat between if using polyester, or thin cloth or epoxy comparable mat, if using epoxy.
Even going to Jamestown Marine two 2' x 4' pieces would be $120 plus shipping. 30 x 30 = 900 sq inches, 24 x 48 = 1152 sq inches... 4 sheets would be $240 vs $395.. (plus shipping)
There are going to probably be cheaper places.
Teufelshunde
Photos: Fishwisher
PostPosted: Mon May 25, 2020 1:43 am    Post subject: Reply with quote
Thanks Bob - I should get a callback on Tuesday and see what their pricing is.
Teufelshunde
Photos: Fishwisher
PostPosted: Sat Jun 20, 2020 1:52 pm    Post subject: Reply with quote
Update:
I ended up going with 4 sheets of 3/4 from the link Barry provided above and have installed the balsa and glassed everything -so far I am happy with the results. I didn’t take pictures of the process because it was 90 degrees out and I had to work at a steady pace but I posted a few pictures in my album of the final sanding. 1708 sure took a lot of epoxy to wet out!
I did have 3 nickel size blisters about 1/8 inch high on the Starboard side when it finished curing, I’m guessing from the temperature that day being high and possibly the balsa below in those places soaking up the wet out I did or air in the resin might have created a “foam” while curing? Anyway I ended up drilling two small holes at an angle on both sides of the nickel blisters and filled with epoxy so that did the trick. BTW I did use a fin roller on each application of mat and meticulously rolled each layer slowly to remove any air keeping track of my working time on the cure. I ended up with 3 layers in an hour and a half time.
I also posted a picture of some mounts on the insides of the boat that I’m curious about - there are 4 of them 2 on each side and wanted to know what they were originally for and was there a balsa core in them because there sure isn’t anymore! Bolted to them was fishing pole holders with rusted out bolts. Pics In my album.
I’ve been on this project for 2 1/2 months almost straight through at 10 hrs a day but I have accomplished a ton. I will start another thread with all I did in that time frame and post before and after pictures in my album for anyone interested.
Salmon has hit our coast so I’m pushing this week to button everything up !
Fish on!!
Page generation time: 0.1111s (PHP: 40% - SQL: 60%) - SQL queries: 32 - GZIP disabled - Debug on
