Storm Dog
State or Province: MS
Vessel Name: Mae-C
Photos: Mae-C
Posted: Fri May 08, 2020 4:33 pm Post subject: Cover o-ring sizes |
Having a hard time finding o ring sizes for the various size covers on our boat. Anyone know the circular covers or ports diameter rings? I can't get at the boat yet so I can't personally measure. I think there may be 2 sizes of circular covers?
Additionally, does anyone have problems using the search function with an I pad? It seems to cut off the additional results beyond 10 or so. Sometimes, the 2nd or 3rd page of results is sized wrong; ie no word wrap and see the complete post. Maybe my machine is just defective.
Thanks
Glenn |
Joined: 02 Nov 2003 Posts: 20858 City/Region: Pensacola
Posted: Fri May 08, 2020 10:33 pm Post subject: |
Are you taking about the fuel fill, the water fill, the waste disposal etc? Or the access ports in the cockpit steps and and floor?
Your boat is within a couple of numbers of mine, so what I have should be the same as yours. I can put a micrometer on the o rings and also measure the diameter, if I know what you need. _________________ Bob Austin
Storm Dog
Vessel Name: Mae-C
Photos: Mae-C
Posted: Sat May 09, 2020 12:29 am Post subject: |
The access ports in the cockpit area. Look to be circular inspection port or covers. Seems I've been able to find the fuel and water and pumpout dimensions in another post. They were old and falling apart. |
Posted: Sat May 09, 2020 2:47 pm Post subject: |
I have replaced the original in mine with West Marine, which have a different "O" ring setup. What you can/should do, is take a tube of silicone grease with you, and coat the old "o" rings. this will work well enough to get the boat "home" to Mississippi. |
Living the dream
Vessel Name: Kit Kat
Photos: Kit Kat
Posted: Thu Jun 04, 2020 3:33 am Post subject: |
I was having trouble finding a supplier myself - my local West Marine had none in stock. Got hooked up with O Rings & Thinks really easy to deal with. https://oringsandthings.com |
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
