Joined: 02 Nov 2003 Posts: 20813 City/Region: Pensacola
Posted: Thu Apr 16, 2020 10:20 pm Post subject: |
John do you have the remote? I am aware you can choose a user profile, which is where you "dial down" (Same with Pronautic/Sterling). I am not sure how accessible the front of the 12-25 (or 40) would be mounted where the standard battery charger was mounted. The remote should allow you do this without laying on your side, head into a cabinet...(or is your unit located in an more easily accessed position (as I did with my last 22, BC under the Galley)? _________________ Bob Austin
gulfcoast john
Joined: 14 Dec 2012 Posts: 989 City/Region: PENSACOLA
C-Dory Year: 2010
Vessel Name: Cat O' Mine
Photos: CAT O' MINE
joechiro30
Posted: Sat Apr 18, 2020 6:47 pm Post subject: |
I installed the charger but now I need to trace the wiring to the three battery terminals. Should the wiring between the charger and the batteries go to each individual battery? I am trying to trace where the wires go from the charger to the battery but there is a jungle of wires I need to sort through. |
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
Posted: Sun Apr 19, 2020 6:58 pm Post subject: |
gulfcoast john wrote: | I do like my Victron 702 precision in calculating amps in and amps out.... |
If your Victron unit does not come with Bluetooth, I highly recommend getting the Bluetooth dongle Victron makes ($50 I think it was). The monitoring app is free.
That dongle has been one the best purchases I've ever made (I'm an "on the anchor" guy too). The Victron tracks an amazing amount of data, but the vast majority of it is useless to the user since one must push button, after button, after button to access it.....not to mention the tiny display. With the app, you get graphs of your usage hour by hour all night long, and a ton of other goodies. You can also set all options from your phone instead of those little buttons.
Don't get me wrong, my Victron 700 provided all the essential info I needed before I starting using the app, but that $50 was more than worth it to me.
P.S. Now when I awake at night worrying about my batteries, instead of getting out of bed to look at the Victron, I can just roll over, grab my phone, and have a quick look. _________________ Sandy McKean
Purchased Tosca in 2014
Re-powered to Yammi 200 in 2015 |
Posted: Sun Apr 19, 2020 9:31 pm Post subject: |
joechiro30 wrote: | I installed the charger but now I need to trace the wiring to the three battery terminals. Should the wiring between the charger and the batteries go to each individual battery? I am trying to trace where the wires go from the charger to the battery but there is a jungle of wires I need to sort through. |
The wiring should go to each individual battery bank. For example if you have two batteries in the "house bank" then they will be wired in parallel and there will be a ground and positive. Generally there is only one ground from the battery charger, which goes to a terminal block near the batteries, and then each battery is connected to that ground thermal block. The individual positive battery wires go to each bank. |
