georgewindsor
Posted: Wed Mar 25, 2020 3:37 am Post subject: Charging Multiple batteries on Suzuki 50 |
theoretically these things should generate 38 amps from the alternator, more than enough to charge more than one battery. does anyone have feedback on this? |
tsturm
Joined: 01 Nov 2003 Posts: 1173 City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Wed Mar 25, 2020 8:30 am Post subject: Re: Charging Multiple batteries on Suzuki 50 |
georgewindsor wrote: | theoretically these things should generate 38 amps from the alternator, more than enough to charge more than one battery. does anyone have feedback on this? |
I charge 2 g31's & 2 g24's off the alt. on my DF175 batt. s/w on both or all, works great 10 yrs now  |
Joined: 02 Nov 2003 Posts: 21538 City/Region: Pensacola
Posted: Wed Mar 25, 2020 10:59 am Post subject: |
The 90 HP Honda pre 2007 only put out 17 amps. The newer and higher HP put out 44 amps. I only had larger Suzuki's but they also put out in the 40 amp range--you will be fine with several batteries. Use a Voltage Sensitive Relay, if the outboard does not have a secondary charging circuit, between the engine start and house battery. On a 16 often "multipurpose batteries" are used and should be of the same type, size and age for best results. _________________ Bob Austin
