Have read most of the kicker threads. Wondering if the
Nancy and Bud
City/Region: Nashville
State or Province: IL
Vessel Name: Emma Mae
Photos: Emma Mae
PostPosted: Sun Feb 23, 2020 10:14 am    Post subject: Have read most of the kicker threads. Wondering if the Reply with quote
transom dimensions of the 19 and the 22 are identical.
Looking for a kicker to add to Tinker Toy and puzzling over shaft length.
The high thrust Mercury 9.9 seems like a good choice.
"C-dory's are the 13th step in a 12 step program for sailors."Marc Grove, Wefings Marine
Yakmandu
City/Region: Lake Lanier
State or Province: GA
C-Dory Model: 19 Angler
Vessel Name: Miss April
Photos: Pops GO!
PostPosted: Sun Feb 23, 2020 10:25 am    Post subject: Reply with quote
I added a kicker to my 2005 Angler 19 last Spring. I went with a Honda 5 hp - standard shaft. I also used a Garelick tilting motor bracket. This allowed me to use the standard length shaft model. The tilting bracket also gets the kicker completely out of the water when not in use.
I like the weight of the 5 hp motor. I remove it when trailering and its easier to put in the truck! I don’t think you will gain much going with the heavier 9.9 hp motor.
Garelick outboard motor bracket
Model 71093
15 hp, 4 cycle, 115# max
I ordered the outboard from Cumberland Marine in TN. They were great. Got the motor in just a couple of days!
http://www.cumberlandwatersports.com/
Patrick Rohde
Miss April
Lake Lanier, GA
Nancy and Bud
Photos: Emma Mae
PostPosted: Sun Feb 23, 2020 8:26 pm    Post subject: Reply with quote
Additional NOOB question. How is shaft length measured? From top of transom to bottom of motor under prop????
Yakmandu
Photos: Pops GO!
PostPosted: Sun Feb 23, 2020 8:46 pm    Post subject: Reply with quote
Here is the reference I used during my research...
Scroll down the page and click on “Shaft Length Guidelines” in sub menu.
https://onlineoutboards.com/collections/honda-5-hp-outboards/products/2020-honda-5-hp-bf5dhshna-outboard-motor
Nancy and Bud
Photos: Emma Mae
PostPosted: Sun Feb 23, 2020 9:03 pm    Post subject: Reply with quote
Thanks. Just what i wanted. Thumbs Up
Page generation time: 0.1288s (PHP: 89% - SQL: 11%) - SQL queries: 22 - GZIP disabled - Debug on
