3M marine grade silicone sealant vs 4200
bmcminn
City/Region: Bellingham
C-Dory Year: 1992
C-Dory Model: 19 Angler
Vessel Name: Polū
Photos: bmcminn
PostPosted: Mon Feb 17, 2020 4:01 pm    Post subject: 3M marine grade silicone sealant vs 4200 Reply with quote
Which one for lazarette hatches? They are a tight fit and did the overdrill and fill with 205 and the screw holes.
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Mon Feb 17, 2020 4:22 pm    Post subject: Reply with quote
Bmcminn,
You will fall in love with butyl rubber tape. Buy it in white, 1/8" x 3/4" and you will rarely need any other caulk. Hinkley Yachts, many of my fellow boaters and I have been using it for years with great success.
The stuff remains pliable, you don't need any chemicals to clean-up and you can roll it in any shape, thickness or size.
It also does not go bad while sitting in your shop, waiting for its next use.
Here is a link to what I have purchased the last two times around. https://www.ebay.com/itm/DEHCO-COLORIMETRICS-BUTYL-TAPE-PUTTY-TAPE-BLACK-GRAY-WHITE-MANY-SIZES/231095305882?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Steve Baum
Homeport of Portsmouth, VA
PostPosted: Mon Feb 17, 2020 4:50 pm    Post subject: Reply with quote
I go with the 4000, it does not turn yellow. The silicon can hold, or it cannot hold--does vary. My own experience with the butyl tape is that unless you can keep the screws and bolts tight, eventually water and dirt will get under it. I know a lot of folks like it--and it is certainly easier, faster, and cheaper for the boat builders to use....but then again, most boat builders do not properly put in solid glass or epoxy potting when they put fasteners thru a hull, into a cored structure.
PostPosted: Mon Feb 17, 2020 5:08 pm    Post subject: Reply with quote
I use butyl only on thru bolted items. If screws are used, sealant. Just what I do. Don’t claim to be an expert. When I replaced our cockpit hatches I used 3M 4000.
srbaum
Vessel Name: Osprey
Photos: Osprey
PostPosted: Mon Feb 17, 2020 6:06 pm    Post subject: Reply with quote
Bmcminn,
Forgot to pass along the photos from my install a year ago in my 26. Did the same thing in my 22 with the same new hatches in my 26, over 7 years ago and zero leaks...
http://www.c-brats.com/modules.php?set_albumName=album2901&op=modload&name=gallery&file=index&include=view_album.php
Page generation time: 0.0294s (PHP: 60% - SQL: 40%) - SQL queries: 18 - GZIP disabled - Debug on
