Problem of the day
Micahbigsur@msn.com
City/Region: Big Sur
Vessel Name: Sierra
Photos: Sierra
PostPosted: Thu Feb 13, 2020 1:47 pm    Post subject: Reply with quote
Like Bob's Admiral, Captain Dana would not want a solution that could not be removed and cleaned, it's a nurse thing!
A different angle might be to drill a hole in the center of the glass plate with a ceramic tile drill bit and a hole into the rotator deep enough for a non metallic peg epoxied in?
Good luck
Micah Curtis and Dana, RN
Micah, KJ6GUF, Dana, KJ6GXG
PostPosted: Thu Feb 13, 2020 3:35 pm    Post subject: Reply with quote
Micah, I am glad to see you are finally taking this problem seriously. We all have our burdens, some just seem more real when it is cold and blowing and raining outside all the time. All the durn time!!
When you go all out and splurge for the $69 dollar model the plate still comes out with the deal glued on. The tape seals the space between the plastic and glass and the flux capacitor zaps any germs that try to get in.
Here it is - another problem solved by this great forum:
C-Green
City/Region: Houghton
Vessel Name: C-Green
Photos: C-Green
PostPosted: Thu Feb 13, 2020 4:53 pm    Post subject: Reply with quote
If your tape fails too soon, try GE silicone. I've used it to caulk the sauna's wood stove flue against a metal plate in the sauna wall. Worked great for many many sauna seasons (sauna season = all year). Once I tried the Permatex high temp (red) gel gasket and it did not last nearly as long as the GE stuff.
here's to good popping, Jay
PostPosted: Thu Feb 13, 2020 5:43 pm    Post subject: Reply with quote
If you need something else - try high temp Loctite RTV 5920 High-Performance Silicone Gasket Maker. It's good to 600F.
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Fri Feb 14, 2020 11:32 am    Post subject: Reply with quote
This is the very popcorn problem that Jason from South of Heaven has been trying to solve for years. Why else would he have moved from the otherwise perfect C-Dory 16 up through
2005 Silverton 35 Motoryacht (Twin 385 Crusaders)
I think that the Silverton has twin flux capacitors in the microwave. Laughing
MartyP
Page generation time: 0.1399s (PHP: 92% - SQL: 8%) - SQL queries: 23 - GZIP disabled - Debug on
