Avidmagnum12
Joined: 23 Mar 2013 Posts: 672 City/Region: Ocklawaha
C-Dory Year: 2011
Vessel Name: C-Otter
Photos: C-Otter
Posted: Sat Jan 18, 2020 2:51 pm Post subject: |
Water leak....check the fitting that go to the water heater. On a friend’s 25 the drain for the water heater was cracked open and there was one loose fitting. Ah ....the joy of boat ownership! Tom _________________ Tom and Joyce Schulke
2004 CD 22 Commuter "Out2C" 03/10 to 06/15 |
Posted: Sat Jan 18, 2020 5:00 pm Post subject: |
Quote: | There is a 1/2 inch of water in the bilge. Normal? |
Yes. Wet bilge. Always an issue. As mentioned, the hatches suck. I replaced them and it solved the issue. If your water pump is mounted low I'd raise it up out of the water. I re-located ours to the port battery shelf and since then, the pump has lasted. Prior to that, it rusted out in no time. _________________ "We can go over there...behind the 'little one'....."
