Vinyl Flooring Discovery
Bob Cat
City/Region: Santa Monica
Vessel Name: Dive Cat
Photos: Dive Cat
PostPosted: Mon Dec 12, 2005 8:18 pm    Post subject: Vinyl Flooring Discovery Reply with quote
Hi, Everyone
In the quest for a high quality, uv resistant, non-slip material for the compressor cover and Armstrong Brackets on Dive Cat, I've found a manufacturer of an industrial vinyl flooring material.
www.lonsealspecialty.com, then to "marine", then to londeck plate or coin. There's a guy here in LA with remnants. 6'wide. I'm thinking of the compressor cover and Armstrong Bracket tops covered with londeck coin in eggshell white.
Look also at the "Teak and Holly" to convert any C-Dory into a high end sloop!
Bob Cat
Papillon
Vessel Name: Papillon
Photos: Papillon
PostPosted: Mon Dec 12, 2005 9:39 pm    Post subject: Reply with quote
Fixing above link:
http://www.lonsealspecialty.com/product-marine.html
Coin Link: http://www.lonsealspecialty.com/londeckco.html
I do like the Teak & Holly look. I will keep this in mind when I start serious renovations on the dory.
Mike Taylor
330-936-1030
Bob Cat
Photos: Dive Cat
PostPosted: Mon Dec 12, 2005 9:58 pm    Post subject: Reply with quote
Thanks for the FIX.
Bob Cat
Bob Cat
Photos: Dive Cat
PostPosted: Tue Dec 13, 2005 7:28 pm    Post subject: Reply with quote
Did some more investigating of this material today with the flooring guy.
We checked his inventory carfully and found he did not have remnants of the exterior grade material, only interior. Big disappointment, especially after they told me the price.
Rolls come 8'wide by 60', or 6'wide by 60'. $44.81 per sq. yd. for a whole roll. $2,389.86. Or, 49.06 per sq yd. for part of a roll.
Back to the drawing board.
Bob Cat
gljjr
City/Region: Fall City
C-Dory Year: 1982
Vessel Name: Migratory Dory
Photos: gljjr
PostPosted: Wed Dec 14, 2005 1:56 am    Post subject: Reply with quote
How about Bed Liner Paint?
http://www.nonslipcoating.com/marine.htm
This stuff is being used now for cross walk marking areas and other stuff. I've read about people using it on their boats and it looks pretty neat. I haven't looked into it more than that but will as I start really getting into what I'm going to do with the 27.
Gary Johnson
KB7NFG
AstoriaDave
City/Region: Astoria
PostPosted: Wed Dec 14, 2005 2:36 am    Post subject: Reply with quote
That looks similar to what Line-X will do for a pickup bed, although Line-X is not DIY. Line-X is really durable, solid stuff. Ain't cheap, but lasts forever. Not sure it comes in anything but black. Typical installation result: http://www2.line-x.com/ns/PhotoGallery.html?now=5946
No affiliation with Line-X.
Dave Kruger
Astoria, OR
Sneaks
Vessel Name: C-Brat
Photos: Jenny B and C-Brat
PostPosted: Wed Dec 14, 2005 9:07 am    Post subject: Reply with quote
Line-x does come in colors, including white, as does Rhino liner. Unfortunately, if you ever experienced crawling around a Line-x covered pickup bed in shorts you'll know that it feels and acts like 60 grade sandpaper. I've had both Line-x and Rhino liner spray versions and the Line-x is superior in truck bed applications but I would suspect the much softer and smoother Rhino lining would work better in boat applications.
Don
CatyMae n Steve
City/Region: Jefferson, OR
Vessel Name: CatyMae
Photos: CatyMae
PostPosted: Wed Dec 14, 2005 9:15 am    Post subject: Reply with quote
I've had Rhino Lining sprayed in the beds of this and my last truck...they stand behind their warranty (my son dropped a humungous compressor in the bed when he moved his auto detailing stuff from California, and put a tear hole all the way through the lining and the bed -- they repaired it immediately) and it really is non-skid and they are flexible in that they can spray different thicknesses according to your needs. I know the one in Tualitin, OR has done boats...they have pictures. It comes in a variety of colors.
Caty
gljjr
C-Dory Year: 1982
Photos: gljjr
PostPosted: Wed Dec 14, 2005 12:32 pm    Post subject: Reply with quote
If you look at the colors on the Durabak site you will see they have both nonskid and smooth colors available. So in the places you want the nonskid you can use it and then use the smooth in other places. It sure isn't cheap stuff but I'm planning on using it or Line-X for the deck of my boat. And no I haven't seen or tried this stuff. Just read what others have stated.
BTW: A lot of people with drift boats are now using Line-X on the bottoms as it is hard and slick enough that hitting rocks doesn't hang up too bad. Plus it prevents some damage to the bottom.
catdogcat
City/Region: Soldotna
C-Dory Year: 1988
Vessel Name: Plankton
Photos: catdogcat - TBA
PostPosted: Wed Dec 14, 2005 1:21 pm    Post subject: Reply with quote
I should have used this stuff to do my floorboards.
http://www.c-brats.com/modules.php?set_albumName=album99&op=modload&name=gallery&file=index&include=view_album.php
Bob Cat
Photos: Dive Cat
PostPosted: Thu Dec 15, 2005 12:19 pm    Post subject: Reply with quote
I like the Durabak product because you can do-it-yourself and it has been used successfully in many marine applications that are harsher than what I expect. You can also apply several coats to build up protection and resiliency, like on top of the Armstrong Brackets where people toss lead weights and drag tanks.
It also has sound dampening qualities. Wonder how it would work on bulkheads and hull interiors?
I think I've found the answer to my immediate needs.
Bob Cat
Page generation time: 0.058s (PHP: 64% - SQL: 36%) - SQL queries: 24 - GZIP disabled - Debug on
