2003 Yamaha F40 Tachometer not reading
CDory23
Photos: CDory23
PostPosted: Sun Nov 24, 2019 5:02 pm    Post subject: 2003 Yamaha F40 Tachometer not reading Reply with quote
Hi all,
My tachometer recently started working intermittently until it finally has just given up. Everything on the Tach is functioning except for the RPM gauge. I have twins so I eliminated the Tachometer itself being the problem by plugging in the green wire (tach wire from flywheel) from the other engine to the tach in question and it read fine. I then followed every inch of the wire looking for loose connections and the integrity of the wire itself. Everything checked out.
I am not sure where to go from here. Is there a sensor or something? The problem has to be on the engine/flywheel itself. Thanks for any help!
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Sun Nov 24, 2019 6:42 pm    Post subject: Re: 2003 Yamaha F40 Tachometer not reading Reply with quote
CDory23 wrote:
Hi all,
Get out the shop manual, might pick up a signal from charging coil or separate coil under flywheel. Lots of times the permanent magnet in the flywheel is rusted & generates a weak signal. Thumbs Up
PostPosted: Sun Nov 24, 2019 11:23 pm    Post subject: Reply with quote
Yuor Yami's and mine are close and I have twins too but, very unfortunately, I am not a mechanic. Wish I could help though. Best to you.
CDory23
Photos: CDory23
PostPosted: Sun Dec 22, 2019 4:51 pm    Post subject: Reply with quote
Update. The problem found was a bad rectifier. This is actually the second time this has happened on this motor. The original rectifier went out at about 750hrs, and I bought a used rectifier. I have about 1,050hrs currently and this time I will most likely buy new. I've always been a main motor/kicker guy but the twins are growing on me for do it yourself maintenance reasons. Its easy to swap out parts between the two motors to troubleshoot issues, instead of potentially buying the part you think may be the problem and having to deal with the hassle of returns. Also, when taking something apart its nice to have a mirror image right next to it. I hope there isn't a deeper issue that keeps making the rectifier fail, but if it happens a 3rd time I will go down that road. Hope this helps anybody that may have this same issue.
Page generation time: 0.0998s (PHP: 20% - SQL: 80%) - SQL queries: 17 - GZIP disabled - Debug on
