Want to replace microwave with electric convection oven
Genianell
City/Region: Eugene
PostPosted: Wed Sep 25, 2019 5:20 am    Post subject: Want to replace microwave with electric convection oven Reply with quote
My 1992 Carver 33 aft cabin came with electric burners and a microwave oven underneath. I rarely (if ever) use a microwave, and would much rather have a convection oven in its place. Any suggestions?
Easyvictor.14
City/Region: Dallas
State or Province: TX
Vessel Name: Easy Victor
Photos: Easy Victor
PostPosted: Wed Sep 25, 2019 9:01 am    Post subject: Reply with quote
I use an Oster toaster oven with a broiler. It’s 1/3 the weight of a small microwave and gives you lots of cooking options.
I dropped the regulator for my Magma grill in the water at lake Powell on our first night there...out comes the Oster and generator and I broiled up a couple filets. Dinner saved. Also, you can bake, toast, broil or just reheat. And, they’re like $40 at Walmart.
"New" 2008 23 Venture.
1992 Boston Whaler Montauk 17
1977 Sea Ray SRV 200 sold 2008
1981 T Craft 26 center console
1981 Silverton 34
1979 Chapparal 187
Many, many other small aluminum, wood and fiberglass toys!!!
PostPosted: Wed Sep 25, 2019 12:19 pm    Post subject: Re: Want to replace microwave with electric convection oven Reply with quote
Have you considered the power requirements of a convection oven and how you will meet them?
Might not be too much of a problem on Shore Power, but are you planning on using one at anchor?
PostPosted: Wed Sep 25, 2019 1:34 pm    Post subject: Reply with quote
The 1993 Carver 33 aft cabin is a lot different than a C Dory. I had an earlier version of the Carver 32 aft cabin which was one of 4 diesel powered which were built. Mine had a single 150 hp Volvo and a 7 KW Westerbeke generator. I suspect that your boat has 350 or 454 blocks, with gas generator from 5 to 7 KW, so that you can support a convection oven.
My RV has a High Pointe combination convection/microwave, which draws either 1200 or 1500 watts (not positive about the power requirement)--this probably would fit the dimensions of your microwave.
We also have a combination micro convection at our home (GE Profile over the range) and A Sharpe combo on the Holiday Rambler we recently sold). We also have a stacked convection/regular at home--and the convection is far better in this unit--which is 220 volts, and a lot higher amperage draw than the over the stove. It is great Oven. But my. wife rarely used the smaller convections. In both the RVs, we use a toaster over over the convection 80% of the time. The smaller convections just don't use a lot of power, and thus don't seem as good as the higher amperage draw.
You can get one of the counter top convection toaster ovens (basically a toaster over with a fan), for less than a built in. Also it probably will work better.
Page generation time: 0.0418s (PHP: 42% - SQL: 58%) - SQL queries: 17 - GZIP disabled - Debug on
