sjhantzis
Joined: 29 Sep 2005 Posts: 63 City/Region: Barters Island
State or Province: ME
Vessel Name: Catleen
Posted: Sun Sep 15, 2019 1:49 pm Post subject: NORCOLD not running on 12v |
2005 25' Cruiser. My NORCOLD stopped running on 12v but runs on shore power. Where is the fuse for the 12v circuit? All other thoughts are welcome. Thanks, SJH |
BrentB
State or Province: IN
Photos: BrentB
sjhantzis
Posted: Sun Sep 15, 2019 5:42 pm Post subject: |
I believe the unit is a 2005 vintage Norcold NR740BB. I was hoping not to have to remove the unit from under the captain seat. There's no other access to the rear of the unit in my 25' cruiser without removal. The wiring diagram shows that it should be wired directly to the batteries. Any chance that's where the DC fuse might be? Thanks, SJH |
BrentB
Photos: BrentB
Posted: Sun Sep 15, 2019 6:13 pm Post subject: |
I dont know how it was wired in the boat . I would locate the wiring and trace it probably to the helm fuse box and start check all fuses visually and with a DVM
Hopefully others will help you |
Micahbigsur@msn.com
Vessel Name: Sierra
Photos: Sierra
Posted: Sun Sep 15, 2019 6:17 pm Post subject: |
On our boat when we replaced the old Norcold fridge we found it easy to remove and replace in a few minutes when we were measuring to see if the slightly larger Isotherm Cruise fridge would fit ( it did so we ordered one and love it) if you check the fuse and all connections for good contact and can't find the problem it may cost more than it is worth to fix, it has given good long service and the new ones can be more efficient. I did have to slightly inlarge the opening for the new fridge. _________________ Micah Curtis and Dana, RN
Micah, KJ6GUF, Dana, KJ6GXG |
Joined: 03 Mar 2005 Posts: 3593 City/Region: Valley Centre
Posted: Sun Sep 15, 2019 7:05 pm Post subject: |
Well, the fridge that was installed in Journey On, a 2005 model, always ran off 12 VDC. When 120 VAC was applied an inverter supplied the 12 VDC to the fridge.
So if it runs on 120 VAC you've got a good fridge, but the 12 VDC supply to the unit is missing. Trace the wires coming out of the unit and see where the 12 VDC stops. If you get 12VDC up to the unit, the break is in the unit. It's not hard to pull the fridge: 6 screws and it just slides out. Thus, just pull it out and check the internal wiring.
Boris |
Posted: Sun Sep 15, 2019 8:21 pm Post subject: |
I seem to remember an in-line fuse behind the unit. I took the refer out once to remove my helm seat and add hinges to it. _________________ "We can go over there...behind the 'little one'....."
Discovery
Joined: 08 Dec 2003 Posts: 1239 City/Region: LOA, UTAH
Vessel Name: Discovery
Photos: Discovery
Posted: Sun Sep 15, 2019 11:59 pm Post subject: |
I believe that on ours, the fuze is on the top of the unit. Just under the seat cushion. Our fridge is located on the port side under the forward dinette seat. _________________
Brent and Dixie,
1984 22' Classic sold 2003
2003 24' TomCat sold 2005
2006 CD 22' Angler Sold 2014
"Free men do not ask permission to bear arms." ~ Thomas Jefferson |
sjhantzis
Posted: Mon Sep 16, 2019 5:19 pm Post subject: |
Pulled the refrigerator and replaced two 10-AMP fuses on top of the unit, both were blown. But, the problem persists. The unit will run on 120v but not on 12v. I suspect a power surge may have fried the 12v circuit. Both fuses are maintaining, so there is no short. Thoughts? There are two sealed power boxes: SP-245 and SP243B. Probably fried? Thanks, SJH[/img] |
BrentB
Photos: BrentB
Posted: Mon Sep 16, 2019 8:03 pm Post subject: |
When you replaced the fuses, did you check the voltage?
Most likely, there is an in line fuse on power lead wire or somewhere like the fuse panel. Tracing the wires might help |
Posted: Mon Sep 16, 2019 8:11 pm Post subject: |
Unfortunately these units have a history of blowing the 12 volt power supply. Mine did that. I replaced with a Nordold 12 volt only. Works great. Had got modify the carriage slightly. It is bigger than the Engle which it replaced. But the Engle was identical to a Norcold which was older. The Engle and old units had the "Swing motor" which runs on 27 volts AC. Mine still ran on 110 V AC. _________________ Bob Austin
jennykatz
Vessel Name: Little Treasurer
Photos: Jennykatz
Posted: Wed Sep 18, 2019 11:37 pm Post subject: Fridge |
We have an 06 Cape Cruiser Venture with a Tundra Fridge that works on 115 AC and 12volt dc The 115ac leg quit working But it works on 12 volt and we have shore power batteries charger So fridge works We only use it when we overnight The Tundra service person said it would be $300 to fix So needless to say I will buy a12volt one when this one dies Jim _________________ retired 8/08 from UAL, still working pt tm
Posted: Thu Sep 19, 2019 2:31 pm Post subject: |
Bob, thataway;
I would assume that the fridge has only 1 ea 12 VDC power supply; fed from the battery or the inverter. So, if it works on AC, either the transfer switch is stuck (if there is one,) or the DC voltage isn't getting to the 12 power supply.
Boris |
BrentB
Photos: BrentB
Posted: Sat Sep 21, 2019 3:00 pm Post subject: |
Post the solution
m2cw is buy new LOL |
Posted: Sat Sep 21, 2019 3:11 pm Post subject: |
Power to 12 volt circuit board, but elements failed on board. No replacement boards available. The 12 volt circuit is separate from 120 volt AC circuit input. Unfortunately it would be easy with a Danfoss compressor which runs directly on 12 volts.. Since the Sawafuji swing motor runs at 60 hz, 20 to 23 volts AC, it must have AC current. The 12 volt circuit board converts the 12.8 V DC to about 11 Volts AC and transformer converts that to 20 to 23 volts DC to run the motor. |
