Marine Boat Repair & Maintenance Videos
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Fri Sep 13, 2019 7:06 pm    Post subject: Marine Boat Repair & Maintenance Videos Reply with quote
http://www.marineengine.com/videos/dangar-marine/?utm_source=MarineEngine.com+Newsletter&utm_campaign=0410158fcb-EMAIL_51_Dangar_Marine_in_VT_09132019&utm_medium=email&utm_term=0_33e29cf73c-0410158fcb-352375173
Used Boat Buying Tips, Advice, Check List
Painting an Outboard Lower Unit
Outboard Motor Timing Belt Replacement
Outboard Rectifier Testing
Rebuilding the Cylinder Head on a 4-Stroke Outboard
Unblocking Outboard Carburetor Jets
Johnson Evinrude Water Pump Impeller Change
Johnson Evinrude Gearcase Bearing Removal
Johnson Evinrude Prop Shaft Installation
Johnson Evinrude Gearcase Bearing Installation
Johnson Evinrude Bearing Carrier Installation
Johnson Evinrude Carburetor Rebuild
Johnson Evinrude Fuel Pump Repair Rebuild
Health Check of an Older Johnson Evinrude Outboard
Johnson Evinrude Prop Shaft Removal
Johnson Evinrude Thermostat Replacement
Adjusting Power Trim Settings to Plane an Outboard Motor
Boat Trailer Jack Stand and Wheel Maintenance
Changing Evinrude Prop Shaft Seals
Cleaning Outboard Cooling Water Passages
Diagnosing a Partially Seized Outboard Motor
How to Find a Leak in a Boat
Finding a Vacuum Leak in an Outboard Motor
How to Change Evinrude Water Pump Impeller and Seals
How to Install a Dual Battery Bank on a Boat
Installing and Testing an Outboard Hydrofoil
Installing and Calibrating an Outboard Tachometer
2-Stroke Outboard Carburetor Synchronization
Outboard Ignition Coils and Spark Plug Wires (HT Leads)
Outboard Motor Manual Tilt and Lock
Outboard Motor Powerhead Cooling
Inspecting Outboard Motor Reed Valves
Outboard Motor Spark Plugs
Outboard Valve Clearance Adjustment
Outboard Gearcase Pressure Tester
Replacing a Head Gasket on an Outboard Motor
Reversing a Yamaha 703 Remote Control Box
Outboard Propeller Selection
How to Set Outboard Ignition with a Timing Light
Tools and Products for Working on Outboard Motors
Diagnosing a Mercury Model 110 Outboard 9.8HP
How to Troubleshoot an Outboard Kill Swi
Brent Barrett
Teufelshunde
City/Region: Sebastopol
Vessel Name: Fish Wisher
Photos: Fishwisher
PostPosted: Sat Sep 14, 2019 12:42 am    Post subject: Reply with quote
Good info .! Thanks for putting this up.
What ever you are, be a good one 🇺🇸
Teufelshunde
Photos: Fishwisher
PostPosted: Wed Oct 16, 2019 11:01 pm    Post subject: Reply with quote
Good video series to check out - SAIL epoxy basics
https://m.youtube.com/watch?v=GEM6CqJQNr8&list=PLKrXmm9fNk0b_btfL4THlghAT6ciaY3hB&index=11
Pacificcoast101
City/Region: Torrance
Vessel Name: No Pressure
Photos: No Pressure
PostPosted: Thu Oct 17, 2019 12:24 pm    Post subject: Reply with quote
Bubble Purge™ SeaStar Hydraulic Steering Bleed Repair OST
https://www.youtube.com/watch?v=0_EqQmSrHeQ
Tips & Tricks Hydraulic Steering- Checks and topping up your fluid.
https://www.youtube.com/watch?v=X2Qi1ETRp8s
Which Boat Hull Cleaner Works Best?
https://www.youtube.com/watch?v=AEGolbLmAYo
From Trash To Gold!!!
https://www.youtube.com/watch?v=GunsIwtw9m4
Phil Garner
2008 Tomcat 255
No Pressure
My Photos
BrentB
Photos: BrentB
PostPosted: Thu Oct 17, 2019 1:06 pm    Post subject: Reply with quote
Permatrims link
https://www.simyamaha.com/PERMATRIMS_s/11628.htm
BrentB
Photos: BrentB
PostPosted: Thu Oct 17, 2019 1:12 pm    Post subject: Reply with quote
Marine How To
Categories
Alternators (6)
Cleaning & Detailing (1)
Decks & Deck Hardware (4)
Drive Train (5)
Electrical (37)
Auto Pilots (1)
Batteries (9)
Charge Management Devices (2)
Galvanic Isolators (1)
Electronics (7)
Engines (9)
Featured (4)
Interior (1)
Mooring & Anchoring (1)
Sanitation Systems (1)
Seacocks, Strainers & Hose Clamps (11)
Solar & Renewable Energy (3)
The Hall of FAIL (1)
Featured Product
BrentB
Photos: BrentB
PostPosted: Thu Oct 17, 2019 1:14 pm    Post subject: Reply with quote
Blue Seas Electrical articles
https://www.bluesea.com/support/articles
AC Circuits
AC Source Selection and Power Distribution
Automatic Charging Relays
Battery Switching
Busbars
Charging and Charge Management
Circuit Protection
DC and AC Circuit Wiring
DC Power Distribution
Inverters
Marine Circuit Design Tools
Materials
Metering
Upgrading Marine Electrics
BrentB
Photos: BrentB
PostPosted: Fri Oct 25, 2019 9:21 pm    Post subject: Reply with quote
Champion Outboard & Inboard Motor Spark Plug Guide
http://www.marineengine.com/parts/champion/?utm_source=MarineEngine.com+Newsletter&utm_campaign=130ca19563-EMAIL_56_SPARK_PLUGS_10252019&utm_medium=email&utm_term=0_33e29cf73c-130ca19563-352375173
NGK Outboard Motor Spark Plug Guide
Table of Contents
Outboard Motor Brand
http://www.marineengine.com/parts/ngk/?utm_source=MarineEngine.com+Newsletter&utm_campaign=130ca19563-EMAIL_56_SPARK_PLUGS_10252019&utm_medium=email&utm_term=0_33e29cf73c-130ca19563-352375173
BrentB
Photos: BrentB
PostPosted: Thu Nov 07, 2019 6:35 pm    Post subject: In Search of the Magic Spray Reply with quote
Ah, the magic spray. The one that loosens bolts, stop squeaks, and bolts the door against corrosion. Every sailor has their favorite brand miracle spray (WD-40, CRC, LPS, CorrosionX, etc.), and that brand will often live up to their expectations. However, as we've found in our testing, some sprays are clearly more magical than others, and many of the biases among sailors aren't fully justified.
https://www.practical-sailor.com/blog/In-Search-of-the-Magic-Spray-12681-1.html?ET=practicalsailor:e41508:1459154a:&st=email&s=p_Blog110719
Page generation time: 0.0368s (PHP: 65% - SQL: 35%) - SQL queries: 22 - GZIP disabled - Debug on
