Quote on new 90hp !
Teufelshunde
City/Region: Sebastopol
Vessel Name: Fish Wisher
Photos: Fishwisher
PostPosted: Tue Sep 10, 2019 8:11 pm    Post subject: Quote on new 90hp ! Reply with quote
Just got a quote on a new 2016 Yamaha 90 with 3yr warranty (buy back from a dealer that closed). The only problem is it is a EXTRA long shaft.
Aren’t the 22 anglers just a long shaft?
The dealer said he could put a plate on it ( I’m think the term is a jack plate) to bring it up if I wanted to go with that option. The price is $ 7495.00 !
If I go with the long shaft 2019 year it’s $8845.00
The dealer would install the Extra long shaft with “plate” - control box - cables and prop ready to go for $8,500.00 and if I wanted the extra warranty + 2 yrs it would add another $653.00
I believe the jack plate would set the motor back a few inches and gain a few pounds but I wouldn’t think that to be a worry and it’s adjustable up/down (manual).
The other thing that’s on my mind is it’s a 2016 motor but I figure it has a warranty from the factory so ??...
Does anyone know of issues with a 2016 Yamaha?
Any other comments or thoughts are appreciated.
What ever you are, be a good one 🇺🇸
jakevolvo@yahoo.com
City/Region: Orting
C-Dory Year: 1986
Vessel Name: C-Told Ya So
Photos: C-Told Ya So
PostPosted: Wed Sep 11, 2019 1:38 am    Post subject: Reply with quote
I paid 11,500 after tax for a 2019 Honda 90 installed with troll control box. 5 year warranty
Teufelshunde
Photos: Fishwisher
PostPosted: Wed Sep 11, 2019 12:42 pm    Post subject: Reply with quote
That’s about what I found to be a normal price so I think I’m going to jump on this deal!!
NORO LIM
City/Region: Olympia
Photos: NORO LIM
PostPosted: Wed Sep 11, 2019 1:20 pm    Post subject: Reply with quote
I would suggest you measure carefully the lengths involved. I know that on a number of boats (mine included) the engines have been mounted too low. Raising my standard length engines to the highest point possible on the transom significantly improved boat performance - speed and mileage. With Permatrims, for instance, you want just the thinnest film of water running over the top of the foil when you're on plane. Make sure the jack will put the engine where you need it.
Bill, Formerly on NORO LIM
2001 CD 16, 2001-2006
2006 CC 23, 2006-2014
MikeR
City/Region: Mill Creek
C-Dory Year: 2016
Photos: MikeR
PostPosted: Wed Sep 11, 2019 3:36 pm    Post subject: Reply with quote
Yamaha had a promotion until a couple of weeks ago (Aug 30) to get the extra 2 yrs warranty at no extra charge, and according to the fine print it applied to outboards manufactured after 2012 so it should have been good on that 2016 too. These promos seemingly come up all the time.
The 2016 is previous generation, the 2019 is current generation which came out in 2017. Looking at weights the difference would be for the 2019: 13lb lighter (new generation) + 10lb lighter (20" vs 25") + wt of jack plate (10+ lbs, at least?) = 33+ lbs lighter, which is also amplified by being set back with the jackplate. The 2017 and newer supposedly have other improvements (according to their sales literature), and I'd also consider resale questions/concerns of fitting the 25" on a 22', and better resale with the new generation 2019 vs 2016, depending on when you might sell in the future.
Surely the 2016 will be a good motor, but might the benefits of the properly fitting 20", current generation 2019 be worth the extra cost? I guess that's the question only you can decide... easy for me to say spring for the 2019 when it's not my money, LOL!
Whichever you decide, enjoy the new power!
-Mike
-Mike
22' C-Dory Cruiser (2016)
16' C-Dory Angler (1989)
10' C-Dory Row Boat (1995)
PostPosted: Wed Sep 11, 2019 5:05 pm    Post subject: Reply with quote
Which ever way you go, be sure that the anti ventilation plate is right at the surface of the water with the boat on a plane. It will make a considerable difference in both economy and speed. I probably would go with the long shaft 2019 or 2020 motor. Either way, you will be getting an excellent outboard.
Teufelshunde
Photos: Fishwisher
PostPosted: Thu Oct 17, 2019 10:03 pm    Post subject: Reply with quote
I ended up going with the long shaft 2019 motor with troll control- when all was said and done it cost 10,000 plus a new yamaha tachometer for around $360 which it shows oil pressure/tilt/engine hours etc.... couldn’t be happier!
Page generation time: 0.0504s (PHP: 43% - SQL: 57%) - SQL queries: 24 - GZIP disabled - Debug on
