Fresh Water vs. Salt Water motor
Ken O
City/Region: West Yellowstone
State or Province: MT
C-Dory Year: 1990
Vessel Name: Ravens' Roost
Photos: Ravens’ Roost
PostPosted: Sat Sep 21, 2019 2:07 pm    Post subject: Fresh Water vs. Salt Water motor Reply with quote
I'm looking at purchasing a C-Dory 22 that has a Yamaha 80 as the main engine. I'm pretty sure this boat has never been in salt water, and I intend to use it in salt water. I understand that Mercury offers a salt water version that has the zincs installed, and maybe has other mods also. Does anyone know if this applies to Yamahas, or are they all "salt water ready." If not, can I add the zincs and whatever else is needed. I'm familiar with outboards, but have never run them in salt water.
PostPosted: Sat Sep 21, 2019 3:03 pm    Post subject: Reply with quote
The type of "zinc" is different for salt and fresh water. Just running the boat in salt water or fresh water and flushing it after ward--leaving the boat out of water should not be a problem....but the zincs should be water specific.
Zinc is salt water, Aluminum is brackish--and some salt water, and Magnesium is for fresh water. The internal and external zincs should be changed as appropriate.
C-Val
City/Region: White Rock
C-Dory Year: 1988
Vessel Name: Seaduced
Photos: C-Val
PostPosted: Sat Sep 21, 2019 3:13 pm    Post subject: Reply with quote
I am not an mechanical expert but I think your personal diligence in washing the motor out after each use is a more important factor than buying a “saltwater series” engine.
I rinse my motors out with fresh water after each use and then use a product called “salt-away” in it after that. I also rinse the outside of the engine and spray wd40 around those parts I can wash well.
Obviously fresh water use is better but because I live near the ocean my use is primarily salt. If I restrained my use because it was salt water I would hardly be able to go out!
By doing the above and then changing impeller and thermostat every two years it’s the best that you can do. Other than that life is too short so enjoy what the salt water has to offer!
That’s my take
David and Val
Writing a sea story with my C-Dory !
1982 22' Classic Popeye
1981 22' Classic Bad Boy Brutus
1988 22' Angler
Ken O
C-Dory Year: 1990
PostPosted: Mon Sep 23, 2019 10:57 am    Post subject: Reply with quote
Thanks a bunch! That's what I need to know.
westward
C-Dory Year: 1985
Vessel Name: TBD
Photos: Steady Eddy
PostPosted: Mon Sep 23, 2019 10:04 pm    Post subject: Reply with quote
"zinc" is really a generic term for a sacrificial anode, though many do contain some zinc. As Bob mentioned, you should use the specific sub-type best suited to your primary type of water use. I believe for saltwater the correct "zinc" is an aluminum alloy less noble than the motor's alloy, not a piece of pure zinc. Check with the mfg. and be sure to get the right type...very important if the boat will be kept in the water for extended periods, esp. in marinas. There is likely a large one on the lower tilt bracket, a couple of small ones at the raw water intakes, and one or more internal anodes protecting the exhaust manifold (ie under the cowling, internal to the engine). There may be others specific to your motor. I suggest you use the product Tef-Gel on the threads of all mounting screws before installation to make removal easier on replacement. Best of luck!!
JMadden
City/Region: Superior
PostPosted: Tue Sep 24, 2019 9:45 am    Post subject: Reply with quote
Which raises the question (from a fresh water only guy)... if you're doing the loop do you change "zincs" as you go from fresh to salt water?? Or is the time spent ( a few months perhaps) not significant enough to warrant the change?
James
PaulNBriannaLynn
City/Region: Fort White
Vessel Name: TBD
Photos: Lorelei
PostPosted: Tue Sep 24, 2019 11:13 am    Post subject: Reply with quote
Where the zincs are going to be most beneficial is along the ICW portion of the route where corrosion is more of a concern. The freshwater portion shouldn't be an issue, just a potential for green algae growth.
We've added some disc shaped sacrificial anodes to the trim tabs, and moor along the ICW on our community dock. Within a few weeks to a month those anodes are almost completely eaten away to nothing and need to be replaced. I would have at least one spare set of those anodes with me and replace them in the water along that route.
2007 22 cruiser sold 10/2021
2009 Parker 23 sold 10/2017
2003 22 cruiser sold 3/2016
Micahbigsur@msn.com
City/Region: Big Sur
Vessel Name: Sierra
Photos: Sierra
PostPosted: Tue Sep 24, 2019 12:00 pm    Post subject: Reply with quote
Saltwater marinas can have a lot of stray current in the water. All the zincs on my motor mount and trim tabs were being eaten so fast in Monterey that I started using the submerged on a cable and clipped to the motor Salty Dog "zinc" left over from my sailboat and now it is doing most of the work.
We have noticed that when we spend most of our time anchored out our zincs need to do very little work.
Micah Curtis and Dana, RN
Micah, KJ6GUF, Dana, KJ6GXG
PostPosted: Tue Sep 24, 2019 4:12 pm    Post subject: Reply with quote
Thinking of going the other way, from Salt to Fresh (at least for half a season) so wondering which of the 3 would be the most useful (as in give up the most -- preventing the most corrosion of the engine and boat metals.
Not sure if that is worded right but I think I should have the most sacrificial of the three, Aluminum, zinc or magnesium. Maybe since most of the time would be in Fresh water I should just change to that one, ("Magnesium is for fresh water'), for that half of the season.
"Zinc is salt water, Aluminum is brackish--and some salt water, and Magnesium is for fresh water"
from Bob Austin.
PostPosted: Tue Sep 24, 2019 6:40 pm    Post subject: Reply with quote
For doing the loop, I would not change zincs.
Page generation time: 0.1208s (PHP: 77% - SQL: 23%) - SQL queries: 29 - GZIP disabled - Debug on
