SOLD - 2012 C-Dory 23 Venture for sale (aka TBD II)
johnf
City/Region: Tigard, OR
PostPosted: Thu Sep 05, 2019 10:07 pm    Post subject: SOLD - 2012 C-Dory 23 Venture for sale (aka TBD II) Reply with quote
We have had 5 amazing summers with this well put together boat. Original owner had 27 fresh water hours on the 150...ours has been a mix of fresh and salt (Columbia/Willamette/San Juans/Gulf Islands/Princess Louisa).
The time has come for a new chapter...we are selling our memory making machine to someone ready for wonderful adventures!!!
We had a 22 from 2005 to 2014...here are some of things we like about the 23 Venture: 10-15% better ride, more speed (when conditions are right), stronger roof (can walk on it), more headroom (I'm 6' 2"), etc.
Please reach me via phone with questions at:
five oh three ... seven two zero ... fourty ninety
or
frazeys@frontier.com
Kind Regards, John.
BOAT:
2012 C-Dory Venture 23'
Hull# CMC23003J1112
Solid Color Hull (Blue)
Hydraulic Steering
Interior Hand Rails
Shore Power w/50 foot cord
Swim Step w/removable L bracket for dinghy kicker
TRAILER:
2012 Magic Tilt w/Spare
P0WER:
2012 Honda 150 hp (Model# BFK150AKL) Approximately 236 hours
Stainless Steel Prop
2012 Honda 15 hp Electric Start w/tilt & trim (Model# BF15D3LRT)
Approximately 5-7 hours 4 Blade Prop
Dual Controls for Honda 150 hp and 15 hp controlled from the Cabin
Removable Steering Rod for 15 hp Steered from main motor.
CANVAS:
King Canvas Camper Back w/3 Screens (Toast Sunbrella Color)
King Canvas Door Screen w/2 Zippers
King Canvas Custom Cockpit Cover (Toast Sunbrella Color)
Interior blue window covers
ADDITIONAL OPTIONS:
Teak and Holly Cabin Floor Covering
Pooderbuilt Aux. Aluminum Outboard Bracket (Custom Built)
Tanner Mirror Polished Stainless Steel Tall Radar Arch
Lewmar 700 Windlass
Yeti Cooler 65 qt Tan w/padded seat top
Dry Flush Battery Operated Head
St Croix Little Crane #175 (Dinghy Lift)
Automatic Bilge Pump
ELECTRONICS:
Garmin GPSMAP 740s Chartplotter/Sounder (touch screen)
Garmin 18"Digital Radar 36nm Range
KVH Azimuth 1000Digital Compass
Raymarine Smart Pilot S1000 Wireless Auto Pilot System
Fusion MS-I700 Marine iPod Dock Sirius AM/FM Stereo Radio (we use USB port for music)
Remote control near door (accessible from rear seat)
2 Bose 131 Marine Speakers (cockpit)
2 Bose 151SE Environmental Speakers (cabin)
Trollmaster PRO3 (controls speed of kicker motor)
VHF GX1700 Compact
Previous owner mentioned Palmer Johnson Yachts Certified Electronics Specialist did the installs
ADDITIONAL:
Barrier Coated Hull (4 Barrier Coats)
VC 17m Extra Antifouling Paint w/Biolux
Zodiac Inflatable w/harness for lifting
Red/white LED cockpit lighting (switch on inside of door)
4 fenders/lines
Honda EU 2000i Generator w/extended run 3.2 gallon fuel tank
IMPROVEMENTS/ADDITIONS:
May 2015 King Canvas custom fitted cover w/covers for radar dome and 150/15 engines
May 2015 installed Bimini upright storage against cabin (velcro straps to entry/exit cockpit handles)
May 2015 moved older hatches inside allowing access under v-berth
- Installed newer more waterproof hatches in cockpit
August 2015 installed Wallas Nordic DT Diesel Stove/Heater w/6 gallon tank
- Controller under steering wheel (can reach from v-berth in the morning)
August 2015 created wood console above center window w/one 12 volt socket and 2 USB charging ports
- Stereo installed in this
May 2018 New Goodyear Endurance Tires (including spare w/cover)
April 2019 New Titan 225 trailer brake assemblies (hydraulic actuator, rotors, pads, etc)
April 2019 New 150 hp impeller (water pump kit) and compression check (good), motor/gear oil change and filter
May 2019 new trailer LEDs (with shrink wrapped sealers) 4 sides markers and 2 rear brake lights
July 2019 Two New Batteries ODY-34M-PC1500ST
- AGM, Sealed Dry Cell, 12 V, Deep Cycle/Starting,
- 850 Cold Cranking Amps, Top Posts, Group 34
- 20Hr Nominal Capacity (Ah) 68
- Reserve Capacity Minutes 135
Dri-deck in cockpit and splash well
Installed 2nd splash well drain hole (port side)
13 lb Galvanized Steel Mantus Anchor w/50 feet of chain and 250 feet of 8 plait line
Custom cut memory foam in v-berth (amazing comfort)
Lewmar v-berth hatch cover w/sliding bug screen or privacy (slides to any percentage of either)
Torqeedo 4 HP Electric Motor - 915 Wh Battery w/custom storage box under table
Installed two 12 volt sockets under rear seat for charging battery/accessories
Small solar panel for battery maintenance (not installed)
2 stainless steel bars that clamp on to roof rails (for kayaks does not include padded rests)
Single burner gas stove (removed from boat when I installed Wallas)
Various oil/water filters, oil and other boat related items
Icom M36 Floating Marine VHF Handheld (110v or 12v charging)
PRICE:
$88,000
johnf
PostPosted: Thu Sep 05, 2019 10:32 pm    Post subject: Reply with quote
Uploaded some various project pics...
johnf
PostPosted: Fri Sep 06, 2019 11:01 pm    Post subject: Reply with quote
Also have a throw bag and life ring that hanging on a hook underneath the starboard rear window in the cockpit...
DayBreak
City/Region: Monmouth, Or.
C-Dory Year: 2018
Vessel Name: DayBreak
Photos: DayBreak
PostPosted: Sat Sep 14, 2019 1:01 am    Post subject: Reply with quote
Hi John. Your 23 Venture is like a new boat. You have taken really good care of it. We must keep in touch. Gary and Colleen.
PostPosted: Sat Sep 14, 2019 3:55 am    Post subject: Reply with quote
WOW, John, Sure hope we still get to see you at Friday harbor and our on the water.
I would add that this boat is near or better than showroom condition. John is that kind of guy, and this boat has been VERY well taken care of.
Wish you, Amy and Teddy all the best in your next adventure.
johnf
PostPosted: Sat Sep 14, 2019 11:20 pm    Post subject: Reply with quote
Thanks Gary, Colleen and Harvey....very kind of you!!
Yes...Amy, Teddi and I hope to get into another boat....just not sure when and what kind yet...
Just trying to take the first step....my heart rate increased the moment I hit the submit button...
For those looking at the items with the boat I forgot to mention I am including the mantus dinghy anchor that has 5 feet of chain and either 50 or 100 feet of line which all fits in a bag you can throw in the dinghy.
Kind Regards,
johnf
PostPosted: Wed Sep 18, 2019 1:38 pm    Post subject: Reply with quote
Price reduced to $86,000
johnf
PostPosted: Sun Oct 06, 2019 7:51 pm    Post subject: Reply with quote
Price reduced to $85,000
johnf
PostPosted: Mon Nov 04, 2019 1:56 pm    Post subject: Reply with quote
Drained the water tank for winter....removed the batteries and put on charger in the garage.
Can still show boat and load batteries if someone is interested in a test ride.
johnf
PostPosted: Mon Jan 06, 2020 7:39 pm    Post subject: Reply with quote
Boat is still for sale....just turned the corner into 2020 and thinking about boating again.
Let me know if anyone is interested in a boat for this summer.
Kind Regards,
DayBreak
C-Dory Year: 2018
Photos: DayBreak
PostPosted: Sun Jan 12, 2020 12:22 am    Post subject: Reply with quote
John, if you still have your boat for sale in May, it would be really nice to see you again along with Amy and Teddy this year at the FHCBGT. You could show off your boat there and give rides for people to see how well and smooth that Honda 150 runs. You have a really nice, like new boat that people really need to see and experience to appreciate. Wish the best for you, Amy and Teddy. Gary.
PostPosted: Sun Jan 12, 2020 12:27 pm    Post subject: Reply with quote
I can't believe this boat is still on the market. It is as close to a showroom boat as you could find anywhere, and it comes with the opportunity to meet Teddy. Oh, and of course, John and Amy are pretty great themselves. A PNW boat that is turn key and beautiful.
John, You guys started with your 22 about the same time as I did with mine. I still remember the roof top dance on the way to Astoria. Just gotta love these boats and their folks.
johnf
PostPosted: Sun Jan 12, 2020 10:11 pm    Post subject: Reply with quote
Thx Harvey....that was a great trip through those waters!!!
Such great memories over the years...
johnf
PostPosted: Sat May 16, 2020 3:37 pm    Post subject: Reply with quote
We have a sale pending on our boat....will be transferring to new owners in the coming weeks.
We will have mixed feelings the day we transfer...so many memories but are excited for the new owners to enjoy coming adventures!!!
Byrdman
Photos: FreeByrd and C-Byrd
PostPosted: Sat May 16, 2020 4:48 pm    Post subject: Reply with quote
Keep us posted. Just sold C-Byrd for the second time. Very mixed feelings.
Awesome boat! I was amazed just how much difference the extra beam width made on the boat. Much easier passing each other with 3 guys in the cabin for sure. If passing your lady, well, the luv aint gone.... but ya may have to reach a little.
Patrick Byrd "Byrdman"
Miss B - CD22A, Aug 2018
Aloysius, Hull # 440 RF-246
TC24, Hull #51, Sold Feb06
CD16A, Sold Dec03
Page generation time: 0.0429s (PHP: 62% - SQL: 38%) - SQL queries: 28 - GZIP disabled - Debug on
