Byrdman
Joined: 06 Nov 2003 Posts: 3320 City/Region: Cumberland River, Clarksville,
Photos: FreeByrd and C-Byrd
Posted: Wed Dec 07, 2005 8:39 am Post subject: 1985 Evenrude 50 HP VRO Fuel Mix |
Need help with the fuel mix ratio of an old 1985 Evenrude 50hp VRO motor. Clues anyone?
Byrdman |
Posted: Wed Dec 07, 2005 9:25 am Post subject: Re: 1985 Evenrude 50 HP VRO Fuel Mix |
Byrdman wrote: | Need help with the fuel mix ratio of an old 1985 Evenrude 50hp VRO motor. Clues anyone?
Byrdman |
VRO stands for Variable Ratio Oiling and is a system designed to mix the oil with the fuel automatically. In general, the fuel:oil ratio varies from 150:1 to 50:1 with the latter at wide open throttle. Some report problems with the earlier systems and just use a 50:1 pre-mix. This is a bit more oil than you need at idle but is (from what I could find on the net) a fairly safe level.
Maybe Gary (gflr) can chime in - he's a mechanic...
Roger on the SeaDNA _________________ Roger on Meant to be |
gljjr
Joined: 27 Jan 2005 Posts: 908 City/Region: Fall City
C-Dory Year: 1982
Vessel Name: Migratory Dory
Photos: gljjr
Posted: Wed Dec 07, 2005 11:43 am Post subject: |
"Former mechanic" is more correct and that on cars! But 50:1 is what we used to run on my old Crestliner with the 115 Merc growing up. And is what I run on my '74 Johnson 25hp. _________________ Gary Johnson
KB7NFG |
Norm S
Joined: 20 Jun 2005 Posts: 110 City/Region: Tacoma Wa
C-Dory Model: 18 Angler
Vessel Name: The Divine Miss C
Photos: The Divine Miss C
Posted: Wed Dec 07, 2005 11:55 am Post subject: |
Patrick, From what I've read on other sites It's not uncommon for the early VRO pumps to fail. A Lot of guys just bypass / disconnect them and go with a straight 50:1 premix. My 84 Evinrude is pre VRO and uses a 50:1 mix.
Norm _________________ If You're not living on the edge you're taking up too much space! |
Byrdman
Posted: Wed Dec 07, 2005 1:55 pm Post subject: |
sounds like a 50:1 ratio going into the tank to me. Thanks guys.
Byrdman |
Larry H
C-Dory Year: 1991
Photos: Nancy H
Posted: Wed Dec 07, 2005 2:26 pm Post subject: |
Patrick,
I was an Evinrude mechanic during the VRO years. If you are going to put 50-1 mix in the tank, be sure to cap off the oil inlet fitting. It is located near the fuel inlet on the motor pan.
After the oil inlet is capped off, you can use mixed fuel in the tank just like a non-VRO motor.
Hope this helps. _________________ Larry H
A C-Brat since Nov 1, 2003
Rabidfish Dealer
Joined: 29 Jul 2005 Posts: 117 City/Region: Noblesville, Indiana
State or Province: IN
Vessel Name: Les Poisson Enrage'
Photos: Rabidfish
Posted: Wed Dec 07, 2005 7:45 pm Post subject: |
While it's true, most of the early VRO's have failed by now, most did not fail "to the bad". The later/current pumps do not vary the oil ratio, but are very reliable. You may want to consider replacement.(if it hasn't been done already)
A two stroke in good condition will really run quite a while, even at idle, without fouling plugs. Most fouling problems are actually misdiagnosed as oil fouling when in fact it's usually caused by poor engine condition(read: poor piston to cylinder wall tolerance)
I have reluctantly replaced many 50hp Johnsons,(dozens) because the owners believed it was a "2 stroke" problem... Only to overhaul these engines to be sold for use by the "Dock installers" and they would idle(dead idle, in gear) for hours on end with no ill effects. _________________ The best things in life come on a stick! |
Adeline
Joined: 03 Nov 2003 Posts: 985 City/Region: Vancouver
Vessel Name: Adeline
Photos: Adeline
C-Otter
C-Dory Year: 1985
C-Dory Model: 22 Classic
Vessel Name: C-Otter
Posted: Wed Dec 07, 2005 10:10 pm Post subject: |
My 1987 90hp VFO Johnson has 400 hours and has never missed a beat. The only thing that has been done is change the plugs every two or three years, and lower unit oil every year. I do not troll with it .
I would like to get a new Johnson 2 stroke or 4 stroke of some kind but its hard to give up a very good engine and convince the keeper of the checkbook that I need $8,000 buck's.
C-Otter |
Adeline
Photos: Adeline
Posted: Wed Dec 07, 2005 11:24 pm Post subject: |
Quote: | My 1987 90hp VFO Johnson has 400 hours and has never missed a beat. The only thing that has been done is change the plugs every two or three years, and lower unit oil every year. I do not troll with it . | Me too except, 1) 1989 70hp, 2) 1600+ hours, 3) I troll for hours on end @ buoy 10 |
Posted: Thu Dec 08, 2005 1:18 am Post subject: |
I got 600 hours out of an '87 Evinrude 90 before trading it in on a 2005 Yamaha 90 EFI. Somebody's still running it. No oil pump problems. But the difference in engines is more like 35 years of technical progress instead of 18! Light years of difference! Joe. _________________ Sea Wolf, C-Brat #31
Byrdman
Posted: Thu Dec 08, 2005 1:00 pm Post subject: |
Larry H: Thanks... That could be what some of the "gagetry" is up around the face of the motor with what simply looked to me as a new uninformed owner of some type of double fuel line set up... Kinda did a big ol hummmm, but was loosing day light hours, it started, it ran... so I took her drove out. Should get some time on the water with her on Friday and will take a couple of pics of what is there. I really appreciate all the feedback. |
