batteries need replacing?
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Sun Aug 25, 2019 10:54 pm    Post subject: Reply with quote
I like this article
https://usbattery.com/wp-content/uploads/2014/05/usb-charging-recommendations.pdf
Brent Barrett
DayBreak
City/Region: Monmouth, Or.
C-Dory Year: 2018
Vessel Name: DayBreak
Photos: DayBreak
PostPosted: Mon Aug 26, 2019 12:21 am    Post subject: Reply with quote
You are correct Dr. Bob. I should not have used the term trickle. That would imply the use of a trickle charger which I would never consider using for long-term storage to keep a battery fully charged. Thanks. Gary.
A Fishin C
Guest
PostPosted: Wed Aug 28, 2019 10:54 am    Post subject: Reply with quote
Thank you all for the input.
I replaced the batteries, but left the wiring the same after checking all the connections .
I think I realize why this suddenly happened after 4-5 years. I put 3 inch zincs on the tabs this year after having 2 inch zincs for all previous years. Maybe the extra weight is causing the extra draw.
PostPosted: Wed Aug 28, 2019 3:18 pm    Post subject: Reply with quote
I doubt that a few oz of zinc would make much significant difference in the current draw. Consider the force when you push down on the tab and the boat is on a plane? Be sure and check out these circuits to be sure there is no defect.
Good boating.
Page generation time: 0.0258s (PHP: 55% - SQL: 45%) - SQL queries: 21 - GZIP disabled - Debug on
