Wallas question
Fishcatcher907
City/Region: Soldotna
Vessel Name: Legacy
Photos: Legacy
PostPosted: Fri Aug 23, 2019 9:25 am    Post subject: Wallas question Reply with quote
So my wife hates the thought of being cold.
Here’s my question. Being as it’s getting close to fall. How much will my stove draw my battery down over night? Should I worry about the boat not starting in the morning?
Cheers
Peter & Judy
City/Region: Olds
State or Province: AB
Vessel Name: Mistaya
Photos: Mistaya
PostPosted: Fri Aug 23, 2019 10:40 am    Post subject: Reply with quote
I have a Wallas and I have worried about that as well. I haven't run it all night, but I have sat out storms for a day or two and run it quite a bit. I have two interchangeable motor/house batteries on my boat that I can switch between. I always keep one fully charged battery switched off for one reason only, to start the boat motor and the other being the house battery that I use for the Wallas, fans, radios etc. If this battery runs out of juice, I still have a full battery to start the motor. I also have solar panels to help keep the batteries full.
I have found that when I use my Wallas as a heater I prefer to leave it on low with the lid open and use a Camfro fan, which has very low energy draw, which I have mounted above the Wallas to circulate the air. I prefer this as it moves the air around better, helps to keep the windows clear and is quieter than the Wallas fan. I also have a Ecofan that can be set right on the Wallas burner and uses no electricity to operate the fan.
Peter & Judy Haase
Buffalo Horn Ranch
HMCB Mistaya
DayBreak
City/Region: Monmouth, Or.
C-Dory Year: 2018
Vessel Name: DayBreak
Photos: DayBreak
PostPosted: Fri Aug 23, 2019 12:17 pm    Post subject: Reply with quote
Fishcatcher907, unless I misunderstand you, you really should have a distribution cluster to protect your start battery fully.
We run our main engine for a few minutes to assist the Wallas on initial start-up because of the high amperage draw. After that, the Wallas runs all night on just a single 24 Series flooded cell battery and stays above 12 Volts. Gary.
PostPosted: Fri Aug 23, 2019 12:54 pm    Post subject: Reply with quote
Or just a battery switch that lets you select only one battery into the circuit. I have two batteries, but only run off one. The second is held in reserve.
PostPosted: Fri Aug 23, 2019 2:50 pm    Post subject: Reply with quote
To get even less 12 volt use, we had an Eco fan--which runs from the stove heat--no 12 volt fans at all.
No problem depleting any of the batteries overnight with the Wallas that way. Once the stove has started the draw is very low. (Starting uses a glow plug)
Fishcatcher907
Vessel Name: Legacy
Photos: Legacy
PostPosted: Fri Aug 23, 2019 3:45 pm    Post subject: Reply with quote
Perfect!
Thanks everyone for the responses!
tsturm
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Fri Aug 23, 2019 4:13 pm    Post subject: Re: Wallas question Reply with quote
Do you have more than 1 battery?
My wallas uses approx 6ah over night on hi
is plenty warm when ambient is 30F or so.
In winter I use the Planar forced air (13,500 BTU) & at 10F ambient it is 60F to 70F in the cabin.
Good luck!! Thumbs Up Beer
Fishcatcher907
Vessel Name: Legacy
Photos: Legacy
PostPosted: Sat Aug 24, 2019 2:37 am    Post subject: Re: Wallas question Reply with quote
Good luck!! Thumbs Up Beer[/quote]
Was that your boat I seen turning down funny river 2 days ago?
tsturm
Photos: JMR-TOO
PostPosted: Sat Aug 24, 2019 7:18 pm    Post subject: Re: Wallas question Reply with quote
Was that your boat I seen turning down funny river 2 days ago?[/quote]
Nope mine is stuck in Seward. Not going to drag it home through the FIRE! Beer
Baxter
City/Region: Sheridan
State or Province: WY
Vessel Name: Baxter ll
PostPosted: Sat Aug 24, 2019 7:47 pm    Post subject: Heater Reply with quote
I bought a portable Mr. Heater propane. No smelly stuff and leaking liquids.
Use mostly for getting dressed etc.
Always warm enough in beeding and a stocking cap which I learned years
ago when did serious backpacking and snow camping.
Keep warm and dry.
What we do for ourselves stays here, what we do for others goes with us
C-Green
City/Region: Houghton
Vessel Name: C-Green
Photos: C-Green
PostPosted: Mon Aug 26, 2019 5:39 pm    Post subject: Reply with quote
The Wallas Nordic's (replacement for the old ceramic top stove) circulation fan does not turn off even with the lid up, so no electric savings using an eco fan. The new Nordic works great but I've always been a fan of Wallas stoves. I think the justification for keeping the fan running is to help keep the computer from overheating.
PostPosted: Mon Aug 26, 2019 10:39 pm    Post subject: Reply with quote
Interesting--do you have one of the Nordic? Not sure I see the logic of running the lid fan to "keep a computer from overheating".
I see that the 85 DT is still available, which can be ordered without a "blower lid". That would be ideal for use of the Eco Fan.
tsturm
Photos: JMR-TOO
PostPosted: Mon Aug 26, 2019 11:17 pm    Post subject: Reply with quote
[quote="thataway
I see that the 85 DT is still available, which can be ordered without a "blower lid". That would be ideal for use of the Eco Fan.[/quote]
He probably meant circuit board. I have the latest greatest & the fan in the lid runs whenever it's on. Beer
MOOSE
State or Province: MN
Vessel Name: MOOSE
Photos: MOOSE
PostPosted: Tue Aug 27, 2019 8:44 am    Post subject: Reply with quote
I just put in a new Nordic in early July and, like Jay, have found it to run great. I'm a fan of them too, when they work properly and I have great hopes the new model will be better than the 17-year-old one we scrapped. While talking with Scan Marine about purchasing the Nordic, I was told that the fan now runs all the time to eliminate a troublesome switch which turned it off when the lid was raised. In fact, we had to send our old one in once to get that repaired. Apparently gunk would fall down into the switch and, over time, prevent it from functioning properly. We used to use an Eco Fan as well, but the new Nordic fan is so much quieter than the old one such that it is no longer objectionable.
Page generation time: 0.0312s (PHP: 76% - SQL: 24%) - SQL queries: 27 - GZIP disabled - Debug on
