how do I post in C-Dorys for sale
tavi
City/Region: cambridge
State or Province: MD
PostPosted: Sun Aug 25, 2019 8:40 am    Post subject: how do I post in C-Dorys for sale Reply with quote
I need help on how to create a post in C-Dorys For Sale and how I can attach a photo file to that. I think that I am in the correct place for the actual post, but the attachment is a problem. An overview would be helpful. Thanks
PostPosted: Sun Aug 25, 2019 12:46 pm    Post subject: Reply with quote
You are on the "C Dory for sale by owner" toward the bottom of the forums: The first forum under C Dory Market Place.
There you have a subject and discussion as you got to this above post. The bottom of that window, has "File name"-pick a file with a photo--should end in JPEG", "PNG" "TIF" or similar photo compression file. Click on your file.--then put a description of the file/photo, in the "file comment" section--then "preview" to view the file, and be sure it is what you want--finally click. "submit".
The most common error is not having the file in a proper format, or having an add blocker.
Page generation time: 0.05s (PHP: 30% - SQL: 70%) - SQL queries: 16 - GZIP disabled - Debug on
