Suzuki DF140 Bogging Down at 2500 RPMs
Goto page 1, 2, 3  Next
Westie
City/Region: Bodega Bay
Vessel Name: True North
Photos: Westie
PostPosted: Fri Aug 09, 2019 8:45 pm    Post subject: Suzuki DF140 Bogging Down at 2500 RPMs Reply with quote
Hi there - hoping for some advice on an engine issue
I have twin 2007 Suzuki DF140s and today the starboard engine shut down at about 3000 rpm as I left the marina. It started fine and idled without issue before we left the slip.
Once it shut down, we pumped the ball and it was collapsed. It wouldn't start at neutral so I rev'ed it a little and started at high RPM. The RPMs were not holding firm so we returned to the slip.
At the slip, we found that it started fine and idled well but couldn't hold consistent RPMs above 2500. It was bogging but not shutting down.
The engine has about 700 hrs. I had replaced the low pressure fuel filter at 400 hr and changed the fuel/water separator recently. Also, the port engine ran perfect so I'm ruling out bad gas.
Everything ran great 10 days ago and the boat is used regularly.
Right now, I'm thinking high pressure fuel filter but that shouldn't need to be changed until 1000 hours.
Any thoughts?
True North
2006 Tomcat 255
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Fri Aug 09, 2019 10:33 pm    Post subject: Reply with quote
Primer bulb new or old and vertical?
All fuel hoses including ones in rigging hoses new or old?
tank vents clear?
Does it have high pressure pump filter?
VST clogged?
Brent Barrett
Westie
Photos: Westie
PostPosted: Fri Aug 09, 2019 11:18 pm    Post subject: Reply with quote
Thanks for the questions. Responses:
- Old and vertical
- Old
tank vents clear?
- Yes
- Yes with 700 hr. PM says change at 1000
VST clogged?
- Not sure how to check.
PostPosted: Sat Aug 10, 2019 12:01 am    Post subject: Reply with quote
Wouldn't the collapsed primer bulb indicate a problem on the tank side? It may be as simple as a clogged screen on the fuel pickup in the tank. It is free to check - unhook the hose from everything beyond the tank and blow through it. If it is plugged, that should dislodge enough to make it run until the screen can be removed and cleaned properly.
It could also be any filters on the tank side of the bulb. If the bulb is flat then the motor fuel system is trying real hard to draw fuel from the upstream side, so the pumps, filters and vapor tank are at least trying to function.
Good luck - I hope it is an easy fix.
Micahbigsur@msn.com
City/Region: Big Sur
Vessel Name: Sierra
Photos: Sierra
PostPosted: Sat Aug 10, 2019 12:34 am    Post subject: Reply with quote
On our shakedown cruise our big new Suzuki ran fine but the new 9.9 sucked the bulb flat and died. Something was installed wrong before the bulb or was defective. I am installing a larger filter/water separator and will replumb the small engine parts, hopefully that will sort it out and since the big motor runs fine and there is a new line from the tank to the filter I know that is not the problem.
If the bulb is sucked flat it seems that the Suzuki 140 problem is before the bulb. Do both run separate lines and filters all the way from the tank? If rhey share any part of the system and one motor runs good then it is good in the shared section.
Micah Curtis and Dana, RN
Micah, KJ6GUF, Dana, KJ6GXG
Micahbigsur@msn.com
Vessel Name: Sierra
Photos: Sierra
PostPosted: Sat Aug 10, 2019 12:42 am    Post subject: Reply with quote
I haven't delt with outboards in decades. I have been sorting out diesel fuel systems and know their problems well, am I missing something on outboard systems with primer bulbs?
Thanks.
Westie
Photos: Westie
PostPosted: Sat Aug 10, 2019 12:53 am    Post subject: Reply with quote
Checked with my buddy and he said the bulb wasn't "collapsed" or "deflated". I don't think the issue is before the bulb.
Also, he pumped it while at high RPM, the engine was running rough and pumping the bulb didn't change anything.
Im thinking its a clog in the VST
bshillam
City/Region: Bellingham
C-Dory Year: 1981
Vessel Name: Heaven To Me
Photos: My Heaven
PostPosted: Sat Aug 10, 2019 10:36 am    Post subject: Reply with quote
I would make sure to change the filters out. Not too expensive to change them out. Also make sure to change the fuel separator. If you have any water in the system it becomes less efficient at separating when near capacity. You may have taken in some water from a source such as a marina. Change all three, water/fuel separator/both filters.
Pacificcoast101
City/Region: Torrance
Vessel Name: No Pressure
Photos: No Pressure
PostPosted: Sat Aug 10, 2019 11:45 am    Post subject: Reply with quote
I had a similar issue once. I checked all the usual suspects before having to be towed back in. It turned out to be a crimped fuel line after the last service was done. I straightened out the line and the problem was solved.
Phil Garner
2008 Tomcat 255
No Pressure
My Photos
anchorout
City/Region: Lake Charles
State or Province: LA
Vessel Name: EZ DUZIT
Photos: EZ DUZIT
PostPosted: Sat Aug 10, 2019 1:33 pm    Post subject: fuel bulb Reply with quote
Had same problem. I pulled the input end of the fuel bulb loose and connected it to a remote 6 gal fuel tank from my dinghy. Pumped the bulb and all ran well. That isolated everything but the fuel feed from the tank. New filter and hose was in good shape. Screen on tank pickup tube was clogged with a piece of plastic.
BrentB
Photos: BrentB
PostPosted: Sat Aug 10, 2019 3:46 pm    Post subject: Reply with quote
Fuel hoses have an inner hose and can separate or kink at sharp bends like going from rigging tube to the under cowling fuel system
Checking the fuel rail pressure will help
I dont have a factory service manual to look at the fuel system
VST is vapor separator tank can accumulate debris and in Yamaha motors, there is high pressure pump inside the VST with a screen filter at the pump bottom. The pump pressurizes the fuel rail to the injectors
. Check rail pressure would be helpful
Westie
Photos: Westie
PostPosted: Sat Aug 10, 2019 8:08 pm    Post subject: Reply with quote
Thanks all!
I ordered new filters and will pull out next weekend for maintenance.
Any input on replacing the H/P Filter?
I read someone say they used a special tool but I don't see what they are referring too.
Anyone do this work themselves, that could offer advice?
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Sat Aug 10, 2019 11:22 pm    Post subject: Reply with quote
Replace [or remove] the check valve on the fuel pickup fitting at the tank . They are a common problem .
Marc
Wefings Marine Website
Since 1909
BrentB
Photos: BrentB
PostPosted: Sun Aug 11, 2019 7:47 pm    Post subject: Reply with quote
Post the answer!
Westie
Photos: Westie
PostPosted: Mon Aug 12, 2019 10:24 pm    Post subject: Reply with quote
BrentB - I will! I am so thankful for this resource!
Pulling the boat out Thursday. I plan to change all filters, spark plugs, inspect all hoses, and valves.
Ordered 3 day delivery from Browns Point. I hate having her unavailable!
Page 1 of 3
Page generation time: 0.0466s (PHP: 64% - SQL: 36%) - SQL queries: 32 - GZIP disabled - Debug on
