Transducer cable
rbfconstruction
City/Region: huntington beach
Photos: Angler Management
PostPosted: Tue Jul 23, 2019 11:28 am    Post subject: Transducer cable Reply with quote
Hi, I just purchased a new gps/fish finder with a transom mount transducer. My old one sat inside the boat (loose) in the bilge well (stern) and worked great. I just wanted to upgrade. My question is this... How do I get the cable to run along the starboard side (inside)? I am afraid of hitting other obstacles and don't want to drill many holes. I am considering exterior mounting. Any advice?
While I got ya, Sounds like 1/4 to 1/2 inch below the lowest bottom point is the censes here. correct?
19 ft.angler
thanks a bill
Richard
cmetzenberg
City/Region: Santa Barbara
Vessel Name: Kanaloa
Photos: Kanaloa
PostPosted: Wed Jul 24, 2019 8:29 am    Post subject: Reply with quote
I just replaced my speed wheel/temp sensor on my transom. As we have different models I can't give you much advice on how to run the cable. However, when I was removing the old cable from the transom i realized that the through hull hole in the transom that this cable passed through was pre made by the factory. I'd examine the interior and exterior of your transom and see if there is filled through hull just waiting to be drilled out to run the wire through.
Conrad Metzenberg
07' Tomcat 255 "Kanaloa"
87' Boston Whaler Guardian 17 (BlackFlag, 03-14)
dgeorges
City/Region: Highlands Ranch
Vessel Name: FRESH FISH
Photos: FRESH FISH
PostPosted: Tue Jul 30, 2019 7:39 pm    Post subject: Reply with quote
I have a lot of experience installing transducers and recently installed three on my CD22. PM or email me with your phone number and we'll chat.
"Ain't no nookie like Chinookie"---Ray Troll
CD 22 Cruiser "FRESH FISH: 2018 to present.
CD 16 Angler "OPA": 2013 to 2019.
Yakmandu
City/Region: Lake Lanier
State or Province: GA
C-Dory Model: 19 Angler
Vessel Name: Miss April
Photos: Pops GO!
PostPosted: Tue Jul 30, 2019 8:40 pm    Post subject: Reply with quote
I recently added a second GPS and transducer to my 2005 19 Angler. I used a SternSaver and was very pleased with how it worked. It wasn’t cheap, but it saved me from drilling any holes in the stern. I ran the cable out the steering boot, through the stern scupper, and down to the SternSaver. I did attach it to the kicker bracket on the way down. Works great.
https://www.westmarine.com/buy/stern-saver--stern-saver-transducer-mounting-block--13553979?recordNum=2
Patrick Rohde
Miss April
Lake Lanier, GA
cgypsy
City/Region: Vancouver Island
Vessel Name: C Gypsy
Photos: C Gypsy
PostPosted: Thu Aug 08, 2019 11:47 am    Post subject: Reply with quote
Is there any interference between the two transducers? Are they in the same area or different parts of the boat?
Gypsy
Life is not about waiting for the storm to pass, it is about learning to dance in the rain.
PostPosted: Thu Aug 08, 2019 12:31 pm    Post subject: Reply with quote
Gypsy, I currently run two transducers on my 22. One for an older Garmin GPSMAP 541, the other for a newer GPSMAP 840. One of the transducers is on the port side the other on the starboard side, about 2 or 3 feet apart. Most the time there is no interference between them. I'm not sure if they use the same frequency or not, but I assume they don't. The newer one also has the down chirp and I know it works on a different frequency. Colby
PostPosted: Thu Aug 08, 2019 1:21 pm    Post subject: Reply with quote
I run two transducers side by side--and have had zero interference issues--just run on different frequencies--modes.
Page generation time: 0.0639s (PHP: 35% - SQL: 65%) - SQL queries: 20 - GZIP disabled - Debug on
