Water pumps pump but deliver no water
GxK
City/Region: Frenchman's Bay, Lake Ontario
State or Province: ON
C-Dory Model: 24 Tomcat
Vessel Name: At Last! ex Goose
PostPosted: Wed Jun 26, 2019 7:37 pm    Post subject: Water pumps pump but deliver no water Reply with quote
On my 2002 TomCat 24, I have a Flojet 4325 series pump for freshwater washdown in the cockpit and a Whale Babyfoot pump in the galley. Both pumps sound like they are pumping but, alas, neither actually delivers any water.
Worked fine for years. Suddenly, no more water.
Looking for advice on how I should systematically find and identify the problem.
Georgs Kolesnikovs
TomCat 24 At Last!
Puffin Saco 12 Finally!
http://tomcat-tales.blogspot.com/
PostPosted: Wed Jun 26, 2019 11:53 pm    Post subject: Reply with quote
A question I would ask is if by any possibility water was left in the pumps during the winter, freezing might well damage valves. The foot pump has a very simple check valve--and that is easily replaced. The Flowjet has 4 valves (quadjet). Either could be damaged, or have debris stuck in the valves. These are also easy to replace--but might be a good idea to tear down first, to double check--and perhaps some obvious problem: Here is the manual, with diagram and parts
I would tear each down--check valves for debris and damage as first stage of a evaluation.
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Thu Jun 27, 2019 2:54 am    Post subject: 24' Cat Reply with quote
Sell the boat to my son. He has been looking for one since his 22' CD was stolen last summer.
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
Micahbigsur@msn.com
City/Region: Big Sur
Vessel Name: Sierra
Photos: Sierra
PostPosted: Thu Jun 27, 2019 11:44 am    Post subject: Reply with quote
First thing is to remove the inlet line on the lower pump and determine if you may have a blockage in the line from the tank if it flows well then considering where you live, follow Bobs advice. Good luck!
Micah Curtis and Dana, RN
Micah, KJ6GUF, Dana, KJ6GXG
Page generation time: 0.032s (PHP: 52% - SQL: 48%) - SQL queries: 17 - GZIP disabled - Debug on
