Ferg
Joined: 18 Jun 2015 Posts: 187 City/Region: Oak Island
Vessel Name: Here & Now
Photos: Here & Now
Posted: Thu Jun 06, 2019 6:33 pm Post subject: I’m thinking of replacing my plotter w/ an 12.9“ IPad |
I like a bunch of apps that are available, and I think that I can get most of the things that my plotter gives me...like Navionics and NOAA’s radar, and view them simultaneously on a big split screen. At $1200 it costs less, with more functionality (on land and sea)
The only thing I think I need is a depth sounder. Does anyone know if there are Bluetooth sounders?
Any thoughts on what I’m forgetting?
Thanks |
Joined: 27 Oct 2012 Posts: 3396 City/Region: SW Michigan
Joined: 02 Nov 2003 Posts: 8555 City/Region: Birch Bay, WA
Posted: Thu Jun 06, 2019 9:11 pm Post subject: |
We did the entire Great Loop (5,428 miles) in 2017 using an iPad on a RAM mount on the underside of the electronics shelf. We used the Garmin Blue Chart mobile app (no longer available), and now the best navigation app by a LONG way is Aqua Map. We concluded at the end of our Loop that all a boater actually needs to is an iPad with Aqua Map, a depth sounder and a VHF radio. You do need a cellular capable iPad to use the GPS function but you don't need a data plan. We used our iPhones as hot spots for the iPad when we needed internet connectivity. You should also have weather apps and a wind / wave height app like SailFlow which do require an internet connection. AIS is nice too, depending on where you cruise. To me, the dedicated chartplotter is a dinosaur, bound for extinction. But then there are those who insist on using paper charts, so people give up what they know and grew up using very hard! _________________
Posted: Fri Jun 07, 2019 4:19 am Post subject: |
Si if you need a phone connection to use the GPS in an I-Pad, what happens when you go where there is no phone service?
SleepyC
![](http://www.c-brats.com/albums/album620/January_2010_342.highlight.jpg) _________________ Though in our sleep we are not conscious of our activity or surroundings, we should not, in our wakefulness, be unconscious of our sleep. |
Ferg
Photos: Here & Now
Posted: Fri Jun 07, 2019 6:27 am Post subject: |
Thanks for your thoughts!
i was stuck on the idea of bluetoothing the sounder, but ssobol had a great solution with the stand-alone sounder.
The only other thing that I would miss is the fuel consumption meter, but I can live without that.
If the entire great loop was happily completed in this fashion, that’s all I need to know.
But I’m looking forward to when someone makes his/her fortune by wirelessly connecting accessories.
I’m aware that I’d need a cellular iPad
Thanks again |
Ferg
Photos: Here & Now
Joined: 01 Mar 2005 Posts: 7449 City/Region: from island boy to desert dweller
Posted: Fri Jun 07, 2019 8:22 am Post subject: |
hardee wrote: | Si if you need a phone connection to use the GPS in an I-Pad, what happens when you go where there is no phone service?
SleepyC
![](http://www.c-brats.com/albums/album620/January_2010_342.highlight.jpg) |
Nope, nope, nope! You do NOT need a phone connection to use the GPS in an iPad. Absolutely. Not just guessing at this. Really. What you need is an iPad that is "cellular capable" but you do not have to sign up for cell service. The GPS chip is in the cellular stuff inside the iPad.
We have owned 6 iPads since they first came out. Used them on boats. In case I didn't mention it: you do NOT need to be connected to cell service to use the GPS function in the iPad. Really. Don't listen to the "genius" in the Apple Store, because they have never run a boat. You need "cellular capable," but you don't need to be connected to a cell tower or pay for a cellular connection.
Yes, there are some apps that require a data connection, and that is what Pat is talking about when "using his iPhone as a hot spot." NONE of the marine nav apps require a cellular connection, other than when loading the area maps (so you do that way before you get on the boat).
People have questioned me on this since I bought that first iPad when Apple released the "cellular and wifi" model (shortly after releasing the initial "wifi only" model. It works. No cellular connection necessary to have the marine nav app fully functional. Honest.
This does NOT work with a "wifi only" iPad. No GPS chip in it. Yes, you can add an external GPS (like the Bad Elf)... but the difference in cost between the "wifi only" iPad and the "wifi and cellular" is about the same as the cost of the external GPS... so why not just get it already built in??
Oh, and it works. Without being around cellular service. Really. Just be sure to buy the "wifi and cellular" model. Our iPads have NEVER been connected to any cell carrier, other than when using my phone as a hot spot. I wouldn't steer you wrong on this. Really.
![Wink](images/smiles/icon_wink.gif) |
drbridge
Vessel Name: Susan Marie
Photos: Susan Marie
Posted: Fri Jun 07, 2019 9:52 am Post subject: |
I can say that we too have had great success using an ipad without having phone service. We purchased an older ipad for a couple hundred dollars from ebay. it is cellular capable with GPS and has wi-fi. I purchased the Navionics ap a couple years ago and downloaded all the maps I would need over Wi-Fi connection. We use it as a redundant chart plotter to our Raymarine C-80. As far as a chart plotter it works just as well as the C-80. We can't get radar or depth on it, but works great as chart plotter. We have to keep it pluged in to a power source when using it because the ipad battery will drain fairly quick and since it is an older navionics ap I can not update the maps because if I do I will loose them all from what I understand. We also use a stand alone depth/fish finder because it gives us a seperate screen for better viewing. I like to have both the c-80 and the ipad on when navigating unfamiliar waters. I keep one zoomed in close and the other further out for better viewing of the maps. _________________ Doug & Susan |
Gene Morris
Joined: 28 Sep 2006 Posts: 424 City/Region: Eureka CA
Vessel Name: Reef Madness
Photos: Reefmadness
Posted: Fri Jun 07, 2019 10:45 am Post subject: |
We purchased IPAD Pro 12.9. three years a go. It is a great addition that is mounted on the Admirals side with a Ram X mount. It does not require cell service to function as a plotter. And it is far superior to my Garmin 3210. If I didn't need the other features, Radar, Autopilot and Sounder, I would get a second iPad for the helm. If you don't have radar, a stand alone sounder would be great and a lot less expensive than a new network machine.
Gene _________________ tight lines |
Posted: Fri Jun 07, 2019 11:38 am Post subject: |
SleepyC
Read it again, Harvey. You do NOT need cell service or an internet connection - you only need a cellular "capable" iPad. The reason is that only cellular "capable" iPads have an internal GPS, the WiFi only iPads do not have a GPS.
Like Bathurst says, the cellular capable iPad works great with nav apps without cell service! |
C-Val
Joined: 15 Sep 2012 Posts: 296 City/Region: White Rock
C-Dory Year: 1988
Vessel Name: Seaduced
Photos: C-Val
Posted: Fri Jun 07, 2019 1:11 pm Post subject: |
Another vote for the iPad with Navionics.
I have a HDS 9” as back up and for radar.
(I didn’t want to use Bluetooth radar to iPad- Furuno first watch- though I considered it. I wanted radar to be hardwired-just in case)
I have a newer cheaper small lowrance 5 for stand alone depth sounder
As far as chart plotter is concerned, the iPad is bigger and the image is more clear. iPad has 2x the pixel count.
The sun on iPad could be an issue if I was outside but for me it never has bothered me.
We also have Navionics on phones just in case
David and Val _________________ Writing a sea story with my C-Dory !
1982 22' Classic Popeye
1981 22' Classic Bad Boy Brutus
1988 22' Angler |
Joined: 30 Sep 2006 Posts: 4664 City/Region: Lake Stevens via Honolulu
Posted: Fri Jun 07, 2019 2:41 pm Post subject: |
The iPad actually saved our Gulf Islands trip last year. An oversight by someone (me) left our Garmin unit useless. See, someone (me) pulled the card out for an update and then didn't re-install it prior to our trip. We got up into the islands and the Garmin lost the charts...while entering Wallace Island. Thankfully, we had the iPad, so crisis averted. ![Rolling Eyes](images/smiles/icon_rolleyes.gif) |
Posted: Fri Jun 07, 2019 3:56 pm Post subject: |
OK then, Thanks to Jim, Pat and the rest. Thank you for clearing that up and making it easy. I-Pads always confuse me.
SleepyC ![Moon](images/smiles/emmoon.gif) |
Ferg
Photos: Here & Now
Posted: Fri Jun 07, 2019 5:31 pm Post subject: |
Okay! I’m beyond convinced....now I need to wait for my current iPad to die....does anybody have a hammer I can borrow |
