Blue Sea Fuse Panel
homerjack
City/Region: Homer
C-Dory Year: 1988
Vessel Name: 49er
Photos: 49er
PostPosted: Tue Jun 04, 2019 9:50 pm    Post subject: Blue Sea Fuse Panel Reply with quote
I am considering replacing the ancient Sea Dog rocker switch panels on my 88 cruiser w 2 Blue Sea six switch panels. Do they mount on cabin side of dash in same manner?
PostPosted: Wed Jun 05, 2019 1:30 am    Post subject: Reply with quote
You should be able to find the exact dimensions of the Blue Seas panels on their site. They should cover about the same area in one panel. If you use a second panel, you may have to do a cut out, and or enlarge the other where the Sea Dog panel was. Be sure and back every circuit with its own Fues. I usually change out the 6 fuse panel for a 12 fuse (or more) panels.
homerjack
City/Region: Homer
C-Dory Year: 1988
Vessel Name: 49er
Photos: 49er
PostPosted: Wed Jun 05, 2019 1:40 am    Post subject: Reply with quote
Thanks Bob. I have more than I'll ever need with the two sixes I currently have so replacing them would be sufficient. Looking at all those soldered connections that need to be redone is daunting though.
Micahbigsur@msn.com
City/Region: Big Sur
Vessel Name: Sierra
Photos: Sierra
PostPosted: Wed Jun 05, 2019 3:33 am    Post subject: Reply with quote
I have installed many Blue Seas breaker panel/switchs and have always found them to be of great quality and easy to wire up. As for all that soldering, check out Practical Sailors long term testing of solder vs. crimped conectors they found out that a properly done high quality crimp was to be prefered, soldering can leave a stiff area of wire that is prone to being brittle and subject to vibration failure.
Micah Curtis and Dana, RN
Micah, KJ6GUF, Dana, KJ6GXG
Page generation time: 0.0271s (PHP: 60% - SQL: 40%) - SQL queries: 17 - GZIP disabled - Debug on
