fuel consumption on 2002 22 cruiser w 100 HP yamaha
John Nousaine
City/Region: SUPERIOR
Vessel Name: pulled the pin
PostPosted: Tue May 14, 2019 7:54 pm    Post subject: fuel consumption on 2002 22 cruiser w 100 HP yamaha Reply with quote
just bought a 2002 22' CRUISER w a 100 HP Yamaha and a 9.9 kicker, wondering what kind of range I can get w 46 gallons of fuel. I was told there was a chart here or on the c-dory site but I can;t find anything. any ideas on how I can ball park economy?
whole lot of things that i never done
but I ain't never had too much fun
PostPosted: Tue May 14, 2019 8:33 pm    Post subject: Reply with quote
I have a 22 Cruiser with the Mercury 115 HP 4 stroke EFI. On Plane, I get about 2.9mpg-3.1mpg. At hull speed (5 mph), about 6mpg. Colby
PostPosted: Tue May 14, 2019 8:59 pm    Post subject: Reply with quote
A lot depends on how you run the boat, and load you have. Colby's numbers seem a little low, on mpg. There have been several performance reviews such as Boat Test.com. These have also been used for the factory brochures and web sites in the past. However these are optimistic, since it usually a new boat, no bottom paint, no water, two persons aboard, and only partial fuel load. Also most of the fuel flow studies are with 2 stroke 70 or 4 stroke 90 hp.
The current brochure gives up to 250 mile range. That would have to be a light boat, and some displacement speed. Figure that you only probably have 22 to 24 gallons usable in each tank. Then add in a 10% factor for "safety". Assume 4 miles per gallon (may be closer to 3.5?)..Lets say a respectable 4 miles per gallon, and 44 gallons usable. That would give 176 mile range less 10%, or about 160 miles. There have been times on long trips, where I have dropped down to displacement speed where you can get over 5 miles per gallon. That would give you about 200 mile range.
This is why I have had fuel flow meters on my C Dorys. Most will give MPG and amount used. They can be quite accurate when calibrated.
CaptMac
City/Region: Amelia Island / Jacksonville
Photos: Blue Manatee
PostPosted: Tue May 14, 2019 9:27 pm    Post subject: fuel consumption 22 cruiser Reply with quote
You should average about 3.5 - 4 mpg depending on weight in boat, speed, prop pitch, hydrofoil and/or trim tabs.
Here's a chart from a similar thread:
Capt Mac Daniel
Flounder Gigging Charters
Amelia Island, Florida 32034
http://www.floundergigging.com
"The Adventure of a Night-time"
904-556-0230 Cell/Text
PostPosted: Tue May 14, 2019 10:54 pm    Post subject: Reply with quote
With my Honda BF90D I plan on 3 smpg at cruising speed. The actual mileage is a bit more than that, but by planning for 3 mpg, a reserve gets built in.
Boat loading makes a difference. This is not just weight, but distribution. Having a lot of tab out to get the ride right will cut the mileage (and top speed) a noticeable amount.
The Boat Test numbers posted are for a minimally loaded boat and are optimistic compared to my boat.
C-Val
City/Region: White Rock
C-Dory Year: 1988
Vessel Name: Seaduced
Photos: C-Val
PostPosted: Tue May 14, 2019 11:10 pm    Post subject: Reply with quote
This does not help you very much but up here in Canada mine works out to 1 1 litre per 1 nautical mile
Very easy for my brain to calculate - 20 nm to gulf islands = 20 litre jug!
Writing a sea story with my C-Dory !
1982 22' Classic Popeye
1981 22' Classic Bad Boy Brutus
1988 22' Angler
PostPosted: Wed May 15, 2019 5:57 am    Post subject: Reply with quote
So:
How would 1 liter per nautical mile compare with 1 statue mile per quart?
Simplification: 1 liter per nautical mile equals (~) 1 gallon per 4 statue miles, or
= 3.5 nautical miles per gallon. (Full Circle)
As usual, your mileage may vary! Laughing
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Wed May 15, 2019 8:46 am    Post subject: Mpg Reply with quote
We have the cc-23 venture with a 115 ct Mercury At cruise 3500 rpm (16mph)we get over 4mpg at 4000 rpm (20mph) about 3.8 or so and the best is at 1500rpm (6mph)and 6mpg In 3 years of running we average out to 3gallons per 1 hour of engine use The venture is about 800lb more then the cd 22.
BTW we had aCD22 with a 90 Hp Suzuki and we would get similar return
John Nousaine
PostPosted: Wed May 15, 2019 9:41 am    Post subject: Reply with quote
thanks everyone. it'll be nice to go to Isle Royal and not have to haul gas cans and sweat it out
:D
PostPosted: Wed May 15, 2019 7:52 pm    Post subject: Reply with quote
Just remember, there are only places to get fuel in Isle Royale. I've been up there the last two years with a small group of C-Brats, and if I leave Grand Portage full, I can get around the island to Rock Harbor and top off, then make it back. (Wendigo Ranger Station is the only other place to get fuel on the Island.) Colby
John Nousaine
PostPosted: Thu May 16, 2019 8:28 am    Post subject: Reply with quote
yup very familiar with the Isle Royale.. fish and or dive it every year. look for "pulled the pin" when your up there. maybe we'll connect
PostPosted: Thu May 16, 2019 8:48 pm    Post subject: Reply with quote
John, if you are around there in July, I believe Tom on C-Otter and some others will be up there soon after the 4th. He loves to fish, and is also a scuba diver. I'll miss out this year, but hope to be back the following year. Colby
cgypsy
City/Region: Vancouver Island
Vessel Name: C Gypsy
Photos: C Gypsy
PostPosted: Fri May 17, 2019 12:57 am    Post subject: Reply with quote
That is exactly how I calculate it and my tanks hold 85 litres each. I'm not sure how much is usable.
Gypsy
Life is not about waiting for the storm to pass, it is about learning to dance in the rain.
Jeff_e_d
City/Region: Snohomish
C-Dory Year: 1998
Vessel Name: Miss Mirth
Photos: Miss Mirth
PostPosted: Mon Apr 26, 2021 12:50 pm    Post subject: Reply with quote
I have a new 115 Yamaha on my 22 Cruiser but don't have the fuel flow meter. expecting much better fuel performance than my honda 75. Both are the same weight and can run same speeds at lower RPM with max speed of much higher if I want it.
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Mon Apr 26, 2021 10:55 pm    Post subject: Reply with quote
I'll give you a resounding maybe on that one....lol....
Page generation time: 0.0525s (PHP: 51% - SQL: 49%) - SQL queries: 28 - GZIP disabled - Debug on
