dwilks
Vessel Name: C-Yalater
Posted: Sat Apr 20, 2019 7:56 pm Post subject: propellers for 25 c-dory with twin 90 hondas |
bent my aluminum props and thinking of buying stainless
Are there any noticeable advantages with stainless props
I have a 25 C-dory with twin honda 90's
We operate out of Prince William Sound and travel pretty far for fishing
Thanks for any input |
Posted: Sat Apr 20, 2019 10:09 pm Post subject: |
Compared to aluminum props Stainless steel are
stronger, harder to bend, slicker (more polished), easier to make in more sophisticated shapes, more expensive, and will give you (properly selected) faster speeds, more gas mileage, less corrosion, and higher repair bills when they're damaged.
Aluminum props are cheaper, slower, offer less gas mileage, cheaper to repair and replace, corrode easier, and less likely to be stolen off your boat/motor.
Best of both worlds:
Get stainless prop(s) for normal use, and aluminum for back-ups and when you're operating in shallow water.
My 2 cents!!
Dora~Jean
Joined: 09 Mar 2004 Posts: 1504 City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
Posted: Sat Apr 20, 2019 11:41 pm Post subject: |
I have 13.5"D x 15"P aluminum 3-blade props on my CD25 with twin Yami 80's, they're essentially perfect for the various loads I carry. I think i could go with 16"P, but not 17's with same diameter. You need to hear from those with your same engine setup. Hope this helps. _________________ Steve
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
+4 Previous, 1/2 sail, 1/2 power |
Posted: Sun Apr 21, 2019 11:13 pm Post subject: |
Quote: | bent my aluminum props and thinking of buying stainless |
To be honest, I never really noticed a difference running SS vs. Aluminum on a prior boat, a SeaRay 268 Sundancer with single 454 Merc. But regarding your bent Aluminum Props. Had that been a SS prop, what kind of damage might it have done to your lower unit? No thanks. I'd just as soon stick with something cheaper that breaks easier than the more expensive part of my drive gear! Colby |
