Replacing Bow Hatch for C-Dory 25 - 2006
mkendrick
City/Region: White Stone
Vessel Name: Nickel 'N' Dymer
Photos: Nickel 'N' Dymer
PostPosted: Thu Apr 04, 2019 9:26 am    Post subject: Replacing Bow Hatch for C-Dory 25 - 2006 Reply with quote
I have water linking into the v-berth. While inspecting the problem I have discovered that there is a substantial crack in the hatch. Where can I get a replacement hatch for a 2006 - 25? Is it difficult to replace?
Mickey and Beth Kendrick
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Thu Apr 04, 2019 12:02 pm    Post subject: Reply with quote
Mickey & Beth,
Give me a call. Replacement of the Lexan is straight forward and inexpensive.
757-477-1453
Steve Baum
Homeport of Portsmouth, VA
PostPosted: Thu Apr 04, 2019 1:30 pm    Post subject: Reply with quote
The Lens of the hatch is available both from Bomar and from various on line suppliers. The sealant is a special silicone. Getting the Lexan lens exactly in the correct location is critical. Also local suppliers can make a lens--but it is critical where the holes for the dogs are placed.
One of the attendees at Hontoon had recently replaced his lens, and the hatch leaked because the dogs were not in the proper location, and the gasket was deformed.
The old sealant can be cut out with a wire or braid between two wooden handles. A few have replaced with safety glass--There are disadvantages to this in my opinion.
Lexan will scratch and can be degraded by UV. There are coatings which mitigate this to some degree. My boat has a thin layer of white Starboard over the hatch, and a solar water tight vent installed, which promotes air circulation in the boat.
Yakmandu
City/Region: Lake Lanier
State or Province: GA
C-Dory Model: 19 Angler
Vessel Name: Miss April
Photos: Pops GO!
PostPosted: Thu Apr 04, 2019 7:39 pm    Post subject: Reply with quote
I just replaced my cracked hatch lens on my 2005 19 Angler. I emailed Bomar with the serial number I found on the inside of the hatch cover. I ordered a replacement lens, gasket, and sealer from Bomar. Followed the directions and the project was a success. Customer service at Bomar was top notch!
Patrick Rohde
Miss April
Lake Lanier, GA
Yakmandu
Photos: Pops GO!
PostPosted: Thu Apr 04, 2019 7:59 pm    Post subject: Reply with quote
Yakmandu wrote:
I just replaced my cracked hatch lens on my 2005 19 Angler. I emailed Bomar with the serial number I found on the inside of the hatch cover. I ordered the replacement lens and gasket from Bomar, and the recommended sealer from Amazon. Followed the directions and the project was a success. Customer service at Bomar was top notch!
PostPosted: Fri Apr 05, 2019 4:59 pm    Post subject: Reply with quote
yakmandu, do you have the email address you used to contact Bowmar? I have not found the right place .... yet.
Thank you,
Yakmandu
Photos: Pops GO!
PostPosted: Fri Apr 05, 2019 6:02 pm    Post subject: Reply with quote
Here is the contact email address... bomar@pompanette.com
Here is the reply I got when I first inquired. It was very detailed and complete. I highly recommend their customer service! Of course, you will need to provide YOUR serial number to get the right replacement lens.
覧覧覧覧覧覧覧覧覧
Thank you for your email. I was able to look up the serial number number the hatch is an N1039-10A this hatch has a clear anodized frame with a smoked lens...the outer dimension of the base of the hatch is 21 13/16 X 21 13/16.. the price on a complete new hatch is $623.00 with a 3 to 4 week lead time. I am sorry we do not offer the lid only to any of our hatches. You can purchase just the lens, the part number for that is P2000-82-1039 with a price of $132.00 with a 4 week lead time.
If you do decide to order the lens only the product that we suggest using to float the lens is called General Electric Ultra Glaze our part number for this in black is P100-75 with a price of $39.00. We do also suggest changing out the gasket in our hatches every 8 to 10 years and the easiest time to do that is when the lens is out of the frame, the part number for the gasket for this hatch is P2000-09 with a price of $7.00 per foot. For this hatch you will need to purchase 7 feet.
To this email I have attached the instructions on how to put in the new lens and how to install the lip gasket for your review.
You can order what you are in need of from us by filling out and returning the attached order form or by calling Customer Service at 603-826-5791. You could also purchase from West Marine, Land N Sea, Defender Industries, Go 2 Marine, or Sailboat Owners.
Best, NELL
Best regards,
Bomar Customer Service Rep.
603-826-5791
PostPosted: Fri Apr 05, 2019 9:11 pm    Post subject: Reply with quote
Thank you for all that info. I don't need to replace the lens, but I would like to replace the gasket or "O" rings for the latches.
Page generation time: 0.0544s (PHP: 44% - SQL: 56%) - SQL queries: 21 - GZIP disabled - Debug on
