Cockpit cover/ deck fitting cu
cptvic
City/Region: Quarryville
Vessel Name: c-pearl
PostPosted: Sat Mar 23, 2019 9:43 am    Post subject: Cockpit cover/ deck fitting cu Reply with quote
We have a cockpit cover that attaches on the back edge of the roof.It slides into a grooved piece that is screwed to the roof.The corners of that piece are breaking.Does anyone know where to buy that or what it is called?Also what would be best to use to fill into screw holes because some of the fiberglass is breaking around the screws.
Randall
City/Region: Salish Sea
Vessel Name: Moonshine
PostPosted: Sat Mar 23, 2019 10:15 am    Post subject: Reply with quote
I believe it's just called awning rail. Here's an example I found:
http://www.rochfordsupply.com/shop/Boating_and_Marine/Awning_Rail/index.html
Randall
island andy
City/Region: rochester hills
PostPosted: Sat Mar 23, 2019 1:04 pm    Post subject: Reply with quote
https://www.sailrite.com/search?keywords=awning%20rail
Here is another source, including plastic versions, which will accommodate the curve of the roof.
andy
andrew g wilson jr
PostPosted: Sat Mar 23, 2019 1:26 pm    Post subject: Reply with quote
Awning railing is available at most RV supply and repair places. It may be cheaper and easier to get than having the item shipped. I favor the aluminum extrusion. It will conform to the room curve. The plastic will eventually chip, and deform to the point it will no longer grip the bolt rope in the fabric.
Page generation time: 0.0841s (PHP: 24% - SQL: 76%) - SQL queries: 21 - GZIP disabled - Debug on
