Camper back on a 23" C-dory.
steveandreina
City/Region: Stanwood
Vessel Name: no name yet
PostPosted: Sat Mar 02, 2019 7:42 pm    Post subject: Camper back on a 23" C-dory. Reply with quote
I have a camper back that I just recently purchased from King marine canvas in Seattle and now need to tow my boat to Oregon and back to Seattle. I was wondering if anyone knows if you can travel with the camper back attached or does it need to be disassembled? And if it needs to be disassembled is there some sort of instructions on how to store the Bimini portion? I looked at if briefly this morning and seems I need to unscrew it from the boat with a screwdriver?
A Fishin C
Guest
PostPosted: Sat Mar 02, 2019 7:49 pm    Post subject: Reply with quote
I would not tow with a camper back or canvas on at highway speeds.
You will wreck it.
40 miles and hour max with canvas would be what i do.
South of Heaven
City/Region: Sharon
Photos: Blue Water
PostPosted: Sat Mar 02, 2019 8:04 pm    Post subject: Reply with quote
What type of distance and speeds are we talking about? If it's more than say, 20 miles and highway speeds then I'd say NO WAY.
If it's all back roads and speeds of 25-35 mph then you'll be fine. Just imagine if you were on the boat and cruising. Try to envision how it would hold up.
If you're worried about removing the whole thing , then just remove the sides and back. Leave the bimini up.
But there is now way I'd drive at highway speeds with the full enclosure up....even with just the bimini I wouldn't do it. Those are like hurricane force winds hitting it from multiple angles. The bimini should be able to be rolled up/depressed without removing it. You can then lay it on it's side or even keep it vertical if you can brace it somehow. You'll need some bungees.
As far as storing it, it depends what type of "plastic" they used. But ideally I'd unzip each panel and lay it flat in the v berth with a bed sheet or tee shirts in between each panel.
You CAN also roll them...But be careful that the metal zips don't bind or go in awkward directions. I would just lay them flat. EASY AND DONE.
<><><> Jason <><><>
Baxter
City/Region: Sheridan
State or Province: WY
Vessel Name: Baxter ll
PostPosted: Thu Mar 14, 2019 6:06 pm    Post subject: 23' Venture Camper Back Towing. Reply with quote
I never would tow with it assembled. It will not hold
together. On our 23' Venture we seldom used the sides and
back.
We share the bunk with them.
However, we do roll and zipper case the bimi part and put it forward and strap to base of radar tower. However demending
on time of year can pu lots of bugs.
WE also never tow with Zodiak inflated. lots of strain and
wind resistance.
Be safe not sorry.
BAXTER II
What we do for ourselves stays here, what we do for others goes with us
Gene Morris
City/Region: Eureka CA
Vessel Name: Reef Madness
Photos: Reefmadness
PostPosted: Fri Mar 15, 2019 9:59 am    Post subject: Reply with quote
I've towed reefmadness from California to Bellingham a number of times.
We take the sides and back off, roll the top around the supports put a cover on it and strap it to the rod holders/rocket launchers. Never had a problem but, the cover is custom made for that purpose. We also have quick release mounts for the supports, slide the lever and supports come out so the only thing in the wind is the tied together supports and a rolled up covered top.
I have some photos of it in my album link below.
http://www.c-brats.com/modules.php?set_albumName=album2700&op=modload&name=gallery&file=index&include=view_album.php
Gene
tight lines
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Fri Mar 15, 2019 4:37 pm    Post subject: Reply with quote
I always took mine off and slipped it into the cabin.
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
PostPosted: Fri Mar 15, 2019 8:20 pm    Post subject: Reply with quote
The one time that I didn't I wished that I had. It's much easier to stow it when at the ramp than when along the side of the road.
Mark
PostPosted: Fri Mar 15, 2019 9:16 pm    Post subject: Reply with quote
My wife made a bag to hold our camperback sections. We put beach towels or a blanket between each section (to protect the eisenglass), then rolled that stack and put it in the tube-shaped bag. The bimini folded back against the cabin with the fabric rolled around the frame. There was a boot made for the rolled up bimini, and we used bungee chords to keep that in place and to keep air from getting in the ends of the roll. It rode fine that way, over thousands of miles of trailering.
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Sat Mar 16, 2019 11:09 am    Post subject: Reply with quote
Same here... it works nicely.
Page generation time: 0.0693s (PHP: 79% - SQL: 21%) - SQL queries: 25 - GZIP disabled - Debug on
