Drain water tank on 25
jkswor
City/Region: tok
Vessel Name: Missy marie
PostPosted: Sat Feb 16, 2019 11:40 am    Post subject: Drain water tank on 25 Reply with quote
Anyone figured out how to drain tank on a 25 ft cdory without using the water pump
Or is there a drain that I’m not seeing?
Thanks
PostPosted: Sat Feb 16, 2019 12:42 pm    Post subject: Reply with quote
Pull the hose off the pump and let it drain. You will get most of it out.
PostPosted: Sat Feb 16, 2019 12:46 pm    Post subject: Reply with quote
Nor knowing all the 25 changes over the years, I can only offer the configuration of Journey On, a 2005 model.
The tank is under the v-berth. A line comes out of the lower port side bullkhead to the pump in the hot water compartment. I installed a filter and drain valve at the point where it comes out of the bulkhead. It doesn't come with either.
A second approach, which is what I used, is to trace where the pump inlet line goes. Drain the tank with the pump. Then, at the lowest point of the inlet line, install a filter and drain valve. that should work wherever your tank is.
PostPosted: Sat Feb 16, 2019 1:14 pm    Post subject: Reply with quote
We have a 2007 like jk. The tank is under the splash well, in the bilge.
PostPosted: Sat Feb 16, 2019 2:29 pm    Post subject: Reply with quote
Yep--the 2007 is back where the holding tank was on the 2003-2005 boats. We have a fresh water wash spigot in the cockpit--just hook a hose up to that and pump the tank dry.
South of Heaven
City/Region: Sharon
Photos: Blue Water
PostPosted: Mon Feb 18, 2019 7:57 pm    Post subject: Reply with quote
My 2007 25 water tank was also under the splash well. From what I remember it was in a hard spot to access (although you don't need to access it very often).
<><><> Jason <><><>
Bauered
City/Region: Park Hills
State or Province: KY
Vessel Name: Blue Moon
PostPosted: Wed Feb 20, 2019 5:16 pm    Post subject: Reply with quote
I have a 2006 25 and the water tank is under the splash well. I have a hot water heater so I open the drain valve on the front of the hot water heater with the water pressurized. the water drains into the Shower pump box and then out the side of the boat.
Page generation time: 0.0313s (PHP: 59% - SQL: 41%) - SQL queries: 24 - GZIP disabled - Debug on
